plx-daq columns problem
Hello
I make a project with arduino mega.
I want to measure more than 6 voltages at once and export the data to excell.I try to finish my code but my problem is that i cant send data to different columns.The only data that i read to excell is the time and the voltage from A0 Pin
  Serial.println("CLEARDATA");
  Serial.println("LABEL,Time,Block 1,Block 2,Block 3,Block 4");
  Serial.println("RESETTIMER");
  int sensorValue = analogRead(A0);
  float voltage = sensorValue * (5.0 / 1023.0);
  Serial.println(voltage);
  sensorValue = analogRead(A2);
  Serial.println(voltage * 3);
  Serial.print("DATA,TIME,");
moderator: added code tags and reformatted code (use CTRL-T in the IDE) to make it more readable
thanks..
any suggestion about my problem??
You need to put a comma between each voltage, like this:
  Serial.print(voltage);
  Serial.print(",");
Pete
