is there a library for PLX-DAQ? I got it working but it was not very pretty! Its control and directives needed to be in all caps with the values comma separated. This was the only way I could get the data to show up in the excel program.
int val = 0;
int val1 = 0;
Serial.begin(9600); // opens serial port, sets data rate to 9600 bps
//int val = 0;
val++;
if (val > 29) Serial.println("CLEARDATA");
Serial.print(byte(68));
Serial.print(byte(65));
Serial.print(byte(84));
Serial.print(byte(44));
Serial.print("TIME");
Serial.println(val1);
//if (val > 29) Serial.println("CLEARDATA");
if (val > 29) val = 0;
val1 = random(50, 75);
ok, was doing things the hard way. Took a step back and now I see how easy it was to do. I need a board so I can smack my self in the head! But hey, I did learn something and that is the big thing.
I am new to Arduino and plx-daq. Very interested in your sketch to talk to plx....can you post new 'easy way' sketch on how you communicate with plx?
Thanks,
k
After mucking around a bit, maybe something like this? -not sure if this is the most efficient way.
int val = 0;
int val1 = 0;
//int val = 0;
