PLX DAQ
Hi there!
I have problem regarding the naming of columns.
By default it shows Date Time Timer Counter and Millis
When I place this in setup
void setup(){
// while the serial stream is not open, do nothing:
while (!Serial)
    // do nothing
  Serial.println("CLEARDATA");
  Serial.println("LABEL,A,B,C, D,E");
The column name does not change but the values enter into excel one by one
When I place it at loop
void loop(){
  value0 = analogRead(flexPin0);         //Read and save analog value from potentiometer
  //Serial.print("DATA,TIME,TIMER");
  Serial.println(value0);               //Print value
  delay (1000);
The column name changes but the data keeps on replacing itself.
Pls help.
P/S: The (!serial) is because I use Leonardo
The above certainly won't work, because you commented out the most important statement.
You need to study the documentation and the example code more carefully:
    // simple print out of number and millis
      Serial.print("DATA,DATE,TIME,TIMER,");
      Serial.print(i++); Serial.print(",");
      Serial.println(millis());
jremington:
Where can I find the example code and documentation?
Where did you find PLX-DAQ? That would be a good place to look.
