i have a problem which is i cant connect the cytron ps2 dualshock shield to my arduino uno. what should i do? do i need to connect the tx and rx first? i also use <Cytron_PS2Shield.h> as my library but i dont really understand how to use the library. plz i need answer ASAP.
i have sent the shield image. plz i need some help ASAP.
Why can’t you?
Most libraries come with examples. Doesn’t that one? Most of the time, when you use a non-core library, you need to post a link to it. This time is not an exception.
With spelling and grammar, obviously.
Original written by:
Cytron Technologies
Modified:
29/06/15 Idris, Cytron Technologies - Point to IDE SoftwareSerial
- Restructure the code style to follow standard Arduino library
#ifndef Cytron_PS2Shield_h
#define Cytron_PS2Shield_h
#include "Arduino.h"
#include <SoftwareSerial.h>
// Arduino Leonardo
#if defined (__AVR_ATmega32U4__)
#define Serial Serial1
#else
#endif
// Define PS2 button to number
enum {
// Digital button
#define PS2_SELECT
#define PS2_JOYSTICK_LEFT
#define PS2_JOYSTICK_RIGHT
#define PS2_START
#define PS2_UP
#define PS2_RIGHT
#define PS2_DOWN
#define PS2_LEFT
#define PS2_LEFT_2
#define PS2_RIGHT_2
#define PS2_LEFT_1
#define PS2_RIGHT_1
#define PS2_TRIANGLE
#define PS2_CIRCLE
#define PS2_CROSS
#define PS2_SQUARE
// Analog button
PS2_JOYSTICK_LEFT_X_AXIS
PS2_JOYSTICK_LEFT_Y_AXIS
PS2_JOYSTICK_RIGHT_X_AXIS
PS2_JOYSTICK_RIGHT_Y_AXIS
PS2_JOYSTICK_LEFT_UP
PS2_JOYSTICK_LEFT_DOWN
PS2_JOYSTICK_LEFT_LEFT
PS2_JOYSTICK_LEFT_RIGHT
PS2_JOYSTICK_RIGHT_UP
PS2_JOYSTICK_RIGHT_DOWN
PS2_JOYSTICK_RIGHT_LEFT
PS2_JOYSTICK_RIGHT_RIGHT
// Check connection status
#define PS2_CONNECTION_STATUS
// Control motor vibrarion
PS2_MOTOR_1
PS2_MOTOR_2
// Read all button
PS2_BUTTON_JOYSTICK
class Cytron_PS2Shield
public:
boolean SERIAL_ERR;
uint8_t ps_data[6];
uint8_t _txpin, _rxpin;
// Software Serial
Cytron_PS2Shield(uint8_t rxpin, uint8_t txpin);
// Hardware Serial
Cytron_PS2Shield();
void begin(uint32_t baudrate);
uint8_t readButton(uint8_t key);
boolean readAllButton();
void vibrate(uint8_t motor, uint8_t value);
void reset(uint8_t reset);
protected:
boolean hardwareSerial;
SoftwareSerial *PS2Serial;
void write(uint8_t data);
uint8_t read(void);
#endif
#include <Servo.h>
pinMode(13, OUTPUT);
pinMode(12, OUTPUT);
pinMode(11, OUTPUT);
int jlyu = analogRead(PS2_JOYSTICK_RIGHT_X_AXIS);
if(jlyu < 25){
digitalWrite(11, HIGH);
digitalWrite(12, LOW);
for(int m = 1022; m < 1023; m++)
digitalWrite(13, m);
delay(10);
else if(jlyu > 235){
digitalWrite(11, LOW);
digitalWrite(12, HIGH);
delay(10);
else{
