PLZ..Help ...Problem in sending DHT11 information in Firebase
Hello…evry one
I have a problem in sending information from DHT11 to firebase (google) I am using NodeMcu
This is my code
#include <ESP8266WiFi.h> // esp8266 library
#include <FirebaseESP8266.h>
#include <FirebaseArduino.h> // firebase library
#include <DHT.h> // dht11 temperature and humidity sensor library
#define FIREBASE_HOST “.firebaseio.com" // Project name address from firebase id
#define FIREBASE_AUTH "
************” // Secret key generated from
firebase
#define WIFI_SSID “boom” // Enter your wifi name
#define WIFI_PASSWORD “12345678” //Enter your wifi password
#define DHTPIN D5 // Digital pin connected to DHT11
#define DHTTYPE DHT11 // Initialize dht type as DHT 11
DHT dht(DHTPIN, DHTTYPE);
WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
Serial.print("Connecting to ");
Serial.print(WIFI_SSID);
Serial.print(“Connecting”);
Serial.print("Connected to ");
Serial.println(WIFI_SSID);
Serial.print("IP Address is : ");
Serial.println(WiFi.localIP()); // Will print local IP address
Firebase.begin(FIREBASE_HOST, FIREBASE_AUTH); // connect to firebase
dht.begin(); //Start reading dht sensor
float h = dht.readHumidity(); // Reading Humidity
float t = dht.readTemperature(); // Read temperature as Celsius
if (isnan(h) || isnan(t)) { // Check if any reads failed.
Serial.println(F(“Failed to read from DHT sensor!”));
return;
Serial.print(“Humidity: “); Serial.print(h);
String fireHumid = String(h) + String(”%”); //convert integer humidity to string humidity
Serial.print("% Temperature: "); Serial.print(t); Serial.println(“C°”);
String fireTemp = String(t) + String(“C°”); //convert integer temperature to string temperature
delay(2000);
Firebase.pushString("/DHT11/Humidity", fireHumid); //setup path and send readings
Firebase.pushString("/DHT11/Temperature", fireTemp); //setup path and send readings
if (Firebase.failed()) {
Serial.print(“pushing /logs failed:”);
Serial.println(Firebase.error());
return;
plz..........help me
And the problem is…?
You’re mixing two Firebase libraries to the same project.
If you want to use the old library, FirebaseArduino.h, just remove #include <FirebaseESP8266.h>
