[PLZ HELP] RA8875 & 5" TOUCHSCREEN - Touch Screen Button Label doesn't display
I'm working with Adafruit RA8875, Adafruit 5" touch screen (PRODUCT ID: 1596 ) and Arduino Mega 2560. I'm trying to create display with touchscreen buttons, label the buttons and add function to the buttons. I've tested the screen using the Adafruit RA8875 library and the examples work perfectly. I'm trying to make a functional button so I've #included Adafruit_GFX.cpp in my sketch and used the following function
btn1.initButton(&tft, 500, 200, 100, 100, RA8875_GREEN, RA8875_BLACK, RA8875_GREEN, "Btn1", 4);
which is included in Adafruit_GFX.cpp but the issue is that the text "Btn1" (button label) doesn't show on the button. I've searched, and looked at different examples but I can't understand what I'm doing wrong. Any help will be appreciated.
#include <SPI.h>
#include "Adafruit_GFX.h"
#include "Adafruit_RA8875.h"
#define RA8875_INT 3
#define RA8875_CS 10
#define RA8875_RESET 9
Adafruit_RA8875 tft = Adafruit_RA8875(RA8875_CS, RA8875_RESET);
uint16_t tx, ty;
Adafruit_GFX_Button btn1;
Adafruit_GFX_Button btn2;
  Serial.println("RA8875 start");
  /* Initialise the display using 'RA8875_800x480' */
  if (!tft.begin(RA8875_800x480)) {
    Serial.println("RA8875 Not Found!");
    while (1);
  tft.displayOn(true);
  tft.GPIOX(true);      // Enable TFT - display enable tied to GPIOX
  tft.PWM1config(true, RA8875_PWM_CLK_DIV1024); // PWM output for backlight
  tft.PWM1out(255);
  //Screen backgroud
  tft.fillScreen(RA8875_BLACK);
  tft.touchEnable(true);
    btn1.initButton(&tft, 500, 200, 100, 100, RA8875_GREEN, RA8875_BLACK, RA8875_GREEN, "Btn1", 1);
    btn2.initButton(&tft, 500, 200, 100, 100, RA8875_GREEN, RA8875_BLUE, RA8875_GREEN, "Btn2", 1);
    btn1.drawButton(false);         //Draw Button 1 on screen
  Serial.print("Status: "); Serial.println(tft.readStatus(), HEX);
  Serial.println("Waiting for touch events ...");
  int Xposn, Yposn;
    if (tft.touched()) {          //Verify the touched area
      Serial.print("Touch: ");
      tft.touchRead(&tx, &ty);  //Read the x and y value of touched area
      Serial.print(tx); Serial.print(", "); Serial.println(ty);
               if (tx > 580 && tx < 680 && ty > 370 && ty < 535)
            btn2.drawButton(); //Draw bnt 2
            delay(100);
            btn1.drawButton();
Did you ever find the problem? I am working on exactly the same type of project.
Thanks.
Try something like this:
tft.drawRect(10, 150, 300, 200, RA8875_GREEN);
tft.drawRect(350, 10, 200, 200, RA8875_CYAN);
tft.drawRect(575, 10, 200, 200, RA8875_CYAN);
tft.drawRect(350, 255, 200, 200, RA8875_CYAN);
tft.drawRect(575, 255, 200, 200, RA8875_CYAN);
/* Change the cursor location and color ... */
// first number indicates how far from the left side the screen the words are (40)
// second number indicates what how far from the top of the screen it is (210)
tft.textSetCursor(40, 210);
tft.textTransparent(RA8875_WHITE);
tft.textEnlarge(3);
tft.textWrite("I WANT");
tft.textSetCursor(350, 38);
tft.textEnlarge(2);
tft.textWrite("A DRINK");
tft.textSetCursor(575, 38);
tft.textEnlarge(2);
tft.textWrite("A BREAK");
tft.textSetCursor(350, 275);
tft.textEnlarge(2);
tft.textWrite("TO EAT");
