Plz the experience of Arduino mega1280 with VRBot
Hi everyone ...... Thank you for Interesting in my topic
now I'm so confuse with the Program and circuit for contact Arduino mega1280 and VRbot >>> " http://www.veear.eu/Products/VRbot.aspx "
what's should I do ?
sorry with my English >>> THX anyway
http://www.kevindarrah.com/?page_id=484
I copy code form Voice Recognition VRBOT in http://www.kevindarrah.com/?page_id=484 website
but It can't for compile for arduino Program
What's should I do?
When you select the Verify button, did a dialog box pop up and say "No. I won't do that!"?
If that is not what happened, then please show the error messages that you received.
Oh!! thx full guy
It's you mean is the error from Arduino Program right?
now I use the program from http://www.kevindarrah.com/?page_id=484
for burn into Arduino mega 1280 although I know It's not support for there but I don't know how to edit something in program after then I burn and it's show me the error like this
27: error: NewSoftSerial.h: No such file or directory In function 'void setup()': In function 'void loop()': In function 'void reset()': Bad error line: -4
so What's should I do the error it's meaning I didn't have library to in could or not?
thank you :P
the support for there is support for arduino another board but it's not for arduino mega1280
how can I do ?
If some one have any program for the basic for arduino mega1280 or have the experiential Please help me >>> THX u
Looks like you haven't installed the NewSoftSerial library
No !!! so how can i got the library about that
thx so much ;D
OK guy now i got the library there and I copy it to my folder libraries already yet and I’m trying for compile again but It’s still can’t to compile same
the program is
#include <NewSoftSerial.h>
int i;
char reader;
NewSoftSerial tx(30,3);// tx on 14
NewSoftSerial rx(2,30);// rx on 12
pinMode(12, OUTPUT);
tx.begin(9600);
rx.begin(9600);
tx.print(‘b’);
for(i=0; i<100; i++){
if(rx.read()==‘o’){
Serial.println(“awake”);
delay(1);
}//for
tx.print(‘x’);
if(rx.read()==‘x’){
Serial.println(“x received”);
delay(1);
}//for
tx.print(’ ');
if(rx.read()==‘A’){
Serial.println(“firmware good”);
delay(1);
}//for
tx.print(‘l’);
tx.print(‘A’);
if(rx.read()==‘o’){
Serial.println(“language set”);
delay(1);
}//for
tx.print(‘o’);
tx.print(‘A’);
if(rx.read()==‘o’){
Serial.println(“Infinite Timeout”);
delay(1);
}//for
tx.print(‘i’);
tx.print(‘B’);
Serial.println(“trigger”);
}//setup
reader = rx.read();
// Serial.println(reader);
if(reader==‘s’){
delay(100);
tx.print(’ ');
reset();
}//read
if(reader==‘F’){
digitalWrite(12, HIGH);
delay(200);
digitalWrite(12, LOW);
if(reader==‘t’){
reset();}
if(reader==‘e’){
reset();}
}//loop
void reset(){
for(i=0; i<1000; i++){
reader = rx.read();
delay(1);
if(reader!=-1)
break;}
delay(100);
tx.print(‘i’);
tx.print(‘B’);
what’s wrong ?or this program is not support for arduinomega 1280 ?
The same problem exists as in your first post. If there is an error in compiling the code, you need to tell us what the error is.
But, the first question that comes to mind is to ask why your are using NewSoftSerial on a board that has 4 hardware serial ports?
That code was not meant to run as-is on any board that has multiple hardware serial ports.
