PMODNAV doesn't work
I have installed the libraries Sparkfun LSMDS1 and Wire. And I have got this on the serial monitor:
Your topic has been moved to a more suitable location on the forum. Installation and Troubleshooting is not for problems with (nor for advice on) your project :wink: See About the Installation & Troubleshooting category.
Is the baud rate in the IDE matching the baud rate in the sketch?
Which Arduino are you using?
Please post your sketch; remember to use code tags as described in How to get the best out of this forum.
I'm using Arduino Uno.
My Sketch:
  Test of Pmod NAV (Based on Jim Lindblom's program)
  Description: Pmod_NAV
  All data (accelerometer, gyroscope, magnetometer) are displayed
  In the serial monitor
  Material
  1. Arduino Uno
  2. Pmod NAV (dowload library
  https://github.com/sparkfun/SparkFun_LSM9DS1_Arduino_Library )
  Licence Beerware
  Wiring
  Module<--------------------> Arduino
  J1 pin 6 (3V3)     to        3V3
  J1 pin 5 (GND)     to        GND
  J1 pin 4 (SCK)     to        A5 (SCL)
  J1 pin 2 (SDI)     to        A4 (SDA)
// The earth's magnetic field varies according to its location.
// Add or subtract a constant to get the right value
// of the magnetic field using the following site
// http://www.ngdc.noaa.gov/geomag-web/#declination
#define DECLINATION -5.55 // declination (in degrees) in Cluj-Napoca (Romania).
#define PRINT_CALCULATED  //print calculated values
//#define PRINT_RAW       //print raw data
// Call of libraries
#include <Wire.h>
#include <SparkFunLSM9DS1.h>
// defining module addresses
#define LSM9DS1_M 0x1E  //magnetometer
#define LSM9DS1_AG 0x6B //accelerometer and gyroscope
LSM9DS1 imu; // Creation of the object
void setup(void)
  Serial.begin(115200); // initialization of serial communication
  Wire.begin();     //initialization of the I2C communication
  imu.settings.device.commInterface = IMU_MODE_I2C; // initialization of the module
  imu.settings.device.mAddress = LSM9DS1_M;        //setting up addresses
  imu.settings.device.agAddress = LSM9DS1_AG;
  if (!imu.begin()) //display error message if that's the case
    Serial.println("Communication problem.");
    while (1);
  //measure
  if ( imu.gyroAvailable() )
    imu.readGyro(); //measure with the gyroscope
  if ( imu.accelAvailable() )
    imu.readAccel(); //measure with the accelerometer
  if ( imu.magAvailable() )
    imu.readMag(); //measure with the magnetometer
  //display data
  printGyro(); // Print "G: gx, gy, gz"
  printAccel(); // Print "A: ax, ay, az"
  printMag(); // Print "M: mx, my, mz"
  printAttitude(imu.ax, imu.ay, imu.az, -imu.my, -imu.mx, imu.mz); //print pitch, roll and heading
//display gyroscope data
void printGyro()
  Serial.print("G: ");
#ifdef PRINT_CALCULATED
  Serial.print(imu.calcGyro(imu.gx), 2);  //calculate angular velocity
  Serial.print(", ");
  Serial.print(imu.calcGyro(imu.gy), 2);
  Serial.print(", ");
  Serial.print(imu.calcGyro(imu.gz), 2);
  Serial.println(" deg/s");               //measured in deg/s
#elif defined PRINT_RAW
  Serial.print(imu.gx);                   //or display raw data
  Serial.print(", ");
  Serial.print(imu.gy);
  Serial.print(", ");
  Serial.println(imu.gz);
#endif
//display accelerometer data
void printAccel()
  Serial.print("A: ");
  Serial.print(imu.calcAccel(imu.ax), 2);   //calculate acceleration
  Serial.print(", ");
  Serial.print(imu.calcAccel(imu.ay), 2);
  Serial.print(", ");
  Serial.print(imu.calcAccel(imu.az), 2);
  Serial.println(" g");                    //measured in g
  Serial.print(imu.ax);                   //or display raw data
  Serial.print(", ");
  Serial.print(imu.ay);
  Serial.print(", ");
  Serial.println(imu.az);
#endif
//display magnetometer data
void printMag()
  Serial.print("M: ");
  Serial.print(imu.calcMag(imu.mx), 2);   //calculate magnetic field components
  Serial.print(", ");
  Serial.print(imu.calcMag(imu.my), 2);
  Serial.print(", ");
  Serial.print(imu.calcMag(imu.mz), 2);
  Serial.println(" gauss");                    //measured in gauss
  Serial.print(imu.mx);                   //or display raw data
  Serial.print(", ");
  Serial.print(imu.my);
  Serial.print(", ");
  Serial.println(imu.mz);
#endif
//display additional calculated values
void printAttitude(float ax, float ay, float az, float mx, float my, float mz)
  float roll = atan2(ay, az); //calculate roll
  float pitch = atan2(-ax, sqrt(ay * ay + az * az));  //calculate pitch
  float heading;  //variable for hading
  //calculate heading
  if (my == 0) {
    heading = (mx < 0) ? PI : 0;
  else {
    heading = atan2(mx, my);
  //correct heading according to declination
  heading -= DECLINATION * PI / 180;
  if (heading > PI) {
    heading -= (2 * PI);
  else if (heading < -PI) {
    heading += (2 * PI);
  else if (heading < 0) {
    heading += 2 * PI;
  //convert values in degree
  heading *= 180.0 / PI;
  pitch *= 180.0 / PI;
  roll *= 180.0 / PI;
  //display calculated data
  Serial.print("Pitch, Roll: ");
  Serial.print(pitch, 2);
  Serial.print(", ");
  Serial.print(roll, 2);
  Serial.println(" °");
  Serial.print("Heading: ");
  Serial.print(heading, 2);
Have you tried changing from 9600 baud in Serial Monitor to same 115200 as you are using in the sketch?
You have a Baud rate mismatch.
Set the serial monitor to the same Baud rate as Serial.begin().
Thanks, now it works
