Hello,
I have an esp-32 connected to a PMS5003, I can hear the fan running inside and the tx and rx pins connected to rx2 and tx2 respectively.
I am using the the following library: https://github.com/avaldebe/PMserial and the hardware serial example and receiving a sensor read timeout message. I am not sure how to solve this issue and would appreciate some advice. I've attatched the code below aswell:
// HardwareSerial1.ino: Read PMS5003 sensor on Serial1
#include <PMserial.h> // Arduino library for PM sensors with serial interface
#if defined(USE_HWSERIAL2)
#define MSG "PMSx003 on HardwareSerial2"
SerialPM pms(PMSx003, Serial2); // PMSx003, UART
#elif defined(USE_HWSERIAL1)
#define MSG "PMSx003 on HardwareSerial1"
SerialPM pms(PMSx003, Serial1); // PMSx003, UART
#else
#define MSG "PMSx003 on HardwareSerial"
SerialPM pms(PMSx003, Serial); // PMSx003, UART
#endif
Serial.println(F("Booted"));
Serial.println(F(MSG));
pms.init();
// read the PM sensor
pms.read();
if (pms)
{ // successfull read
#if defined(ESP8266) || defined(ESP32)
// print formatted results
Serial.printf("PM1.0 %2d, PM2.5 %2d, PM10 %2d [ug/m3]\n",
pms.pm01, pms.pm25, pms.pm10);
if (pms.has_number_concentration())
Serial.printf("N0.3 %4d, N0.5 %3d, N1.0 %2d, N2.5 %2d, N5.0 %2d, N10 %2d [#/100cc]\n",
pms.n0p3, pms.n0p5, pms.n1p0, pms.n2p5, pms.n5p0, pms.n10p0);
if (pms.has_temperature_humidity() || pms.has_formaldehyde())
Serial.printf("%5.1f °C, %5.1f %%rh, %5.2f mg/m3 HCHO\n",
pms.temp, pms.rhum, pms.hcho);
#else
// print the results
Serial.print(F("PM1.0 "));
Serial.print(pms.pm01);
Serial.print(F(", "));
Serial.print(F("PM2.5 "));
Serial.print(pms.pm25);
Serial.print(F("PM10 "));
Serial.print(pms.pm10);
Serial.println(F(" [ug/m3]"));
Serial.print(F("N0.3 "));
Serial.print(pms.n0p3);
Serial.print(F("N0.5 "));
Serial.print(pms.n0p5);
Serial.print(F("N1.0 "));
Serial.print(pms.n1p0);
Serial.print(F("N2.5 "));
Serial.print(pms.n2p5);
Serial.print(F("N5.0 "));
Serial.print(pms.n5p0);
Serial.print(F("N10 "));
Serial.print(pms.n10p0);
Serial.println(F(" [#/100cc]"));
Serial.print(pms.temp, 1);
Serial.print(F(" °C"));
Serial.print(pms.rhum, 1);
Serial.print(F(" %rh"));
Serial.print(pms.hcho, 2);
Serial.println(F(" mg/m3 HCHO"));
#endif
{ // something went wrong
switch (pms.status)
case pms.OK: // should never come here
break; // included to compile without warnings
case pms.ERROR_TIMEOUT:
Serial.println(F(PMS_ERROR_TIMEOUT));
case pms.ERROR_MSG_UNKNOWN:
Serial.println(F(PMS_ERROR_MSG_UNKNOWN));
case pms.ERROR_MSG_HEADER:
Serial.println(F(PMS_ERROR_MSG_HEADER));
case pms.ERROR_MSG_BODY:
Serial.println(F(PMS_ERROR_MSG_BODY));
case pms.ERROR_MSG_START:
Serial.println(F(PMS_ERROR_MSG_START));
case pms.ERROR_MSG_LENGTH:
Serial.println(F(PMS_ERROR_MSG_LENGTH));
case pms.ERROR_MSG_CKSUM:
Serial.println(F(PMS_ERROR_MSG_CKSUM));
case pms.ERROR_PMS_TYPE:
Serial.println(F(PMS_ERROR_PMS_TYPE));
// wait for 10 seconds
delay(10000);
