PMS7003 connector doubt
I just got my hands on a PMS7003 sensor for a air quality monitoring project. The thing is I've never seen the port given on it and on further research I found an adapter which I could potentially use:
PMS7003 sensor adapter
But, I'm not sure if it can be shipped to India. So if any of you guys know any other alternative methods to connect it to an Arduino Nano please enlighten me. Thank you in advance.
I added the connector to a shopping basket and went to checkout. You can select India in the drop down list, so presumably they will ship to you. I entered a fake address in Mumbai and it will cost you $35.36 for DHL express delivery! There didn't seem to be another shipping option.
Another website I found says that the connector is a 2x5 pin with a 1.27mm pitch. You should be able to locate just the connector and solder wires to it.
Thank you very much. I just tried the same thing and got quoted $35.36 dollars as well. I'll try the connector you mentioned. Once again thanks :slight_smile:
