i am trying to read a nfc tag with using a arduino-uno-wifi and adafriut-pn532. i have installed the don/ndef library from github and its not quite working. it might mbe as simple as pointer/reference mistakes as i’m a bginner in embeded systems. here is the output of the tag (external):
Found an ISO14443A card
UID Length: 7 bytes
UID Value: 0x04 0x8D 0x71 0x9A 0x27 0x49 0x80
Seems to be an NTAG2xx tag (7 byte UID)
PAGE 00: 04 8D 71 70 .�qp
PAGE 01: 9A 27 49 80 �'I�
PAGE 02: 74 48 00 00 tH..
PAGE 03: E1 10 10 00 �...
PAGE 04: 01 03 A0 10 ..�.
PAGE 05: 44 03 4C 94 D.L�
PAGE 06: 1C 05 63 68 ..ch
PAGE 07: 2E 6F 77 69 .owi
PAGE 08: 74 65 63 2E tec.
PAGE 09: 74 69 6D 65 time
PAGE 10: 74 72 61 63 trac
PAGE 11: 6B 69 6E 67 king
PAGE 12: 3A 73 74 61 :sta
PAGE 13: 6D 70 39 38 mp98
PAGE 14: 37 36 34 54 764T
PAGE 15: 0F 16 61 6E ..an
PAGE 16: 64 72 6F 69 droi
PAGE 17: 64 2E 63 6F d.co
PAGE 18: 6D 3A 70 6B m:pk
PAGE 19: 67 63 68 2E gch.
PAGE 20: 6F 77 69 74 owit
PAGE 21: 65 63 2E 74 ec.t
PAGE 22: 69 6D 65 74 imet
PAGE 23: 72 61 63 6B rack
PAGE 24: 69 6E 67 FE ing�
PAGE 25: 00 00 00 00 ....
PAGE 26: 00 00 00 00 ....
PAGE 27: 00 00 00 00 ....
PAGE 28: 00 00 00 00 ....
PAGE 29: 00 00 00 00 ....
PAGE 30: 00 00 00 00 ....
PAGE 31: 00 00 00 00 ....
PAGE 32: 00 00 00 00 ....
PAGE 33: 00 00 00 00 ....
PAGE 34: 00 00 00 00 ....
PAGE 35: 00 00 00 00 ....
PAGE 36: 00 00 00 BD ...�
PAGE 37: 00 00 00 FF ...�
PAGE 38: 00 05 00 00 ....
PAGE 39: 00 00 00 00 ....
PAGE 40: 00 00 00 00 ....
which i output like this
success = nfc.readPassiveTargetID(PN532_MIFARE_ISO14443A, uid, &uidLength);
// It seems we found a valid ISO14443A Tag!
if (success)
// 2.) Display some basic information about the card
Serial.println("Found an ISO14443A card");
Serial.print(" UID Length: ");Serial.print(uidLength, DEC);Serial.println(" bytes");
Serial.print(" UID Value: ");
nfc.PrintHex(uid, uidLength);
Serial.println("");
if (uidLength != 7)
Serial.println("This doesn't seem to be an NTAG203 tag (UUID length != 7 bytes)!");
uint8_t data[64];
uint8_t tmp[64];
// We probably have an NTAG2xx card (though it could be Ultralight as well)
Serial.println("Seems to be an NTAG2xx tag (7 byte UID)");
Serial.flush();
//debug
for (uint8_t i = 0; i < 41; i++)
success = nfc.ntag2xx_ReadPage(i, tmp);
if(i == 3)
memcpy(data, tmp, 32);
// Display the current page number
Serial.print("PAGE ");
if (i < 10)
Serial.print("0");
Serial.print(i);
Serial.print(i);
Serial.print(": ");
// Display the results, depending on 'success'
if (success)
// Dump the page data
nfc.PrintHexChar(tmp, 4);
Serial.println("Unable to read the requested page!");
i would like to read the ndef-record with the following:
success = nfc.ntag2xx_ReadPage(3, data);
if (! success)
Serial.println("Unable to read the Capability Container (page 3)");
return;
// If the tag has already been formatted as NDEF, byte 0 should be:
// Byte 0 = Magic Number (0xE1)
// Byte 1 = NDEF Version (Should be 0x10)
// Byte 2 = Data Area Size (value * 8 bytes)
// Byte 3 = Read/Write Access (0x00 for full read and write)
if (!((data[0] == 0xE1) && (data[1] == 0x10)))
Serial.println("This doesn't seem to be an NDEF formatted tag.");
Serial.println("Page 3 should start with 0xE1 0x10.");
// 4.) Determine and display the data area size
dataLength = data[2]*8;
Serial.print("Tag is NDEF formatted. Data area size = ");
Serial.print(dataLength);
// NfcTag t1 = NfcTag(uid, uidLength, "sP", *data, &dataLength);
NfcTag t1 = NfcTag(uid, uidLength, "sP", data, &dataLength);
Serial.println("output tag");
t1.print();
NdefMessage m1 = t1.getNdefMessage();
Serial.println("got message");
NdefRecord r = m1.getRecord(0);
byte l = r.getPayloadLength();
byte payload[l];
r.getPayload(payload);
// Print the Hex and Printable Characters
Serial.print(" Payload (HEX): ");
PrintHexChar(payload, l);
// Force the data into a String (might work depending on the content)
// Real code should use smarter processing
String payloadAsString = "";
for (int c = 0; c < l; c++) {
payloadAsString += (char)payload[c];
Serial.print(" Payload (as String): ");
Serial.println(payloadAsString);
this always shows me empty payloads. why can’t i seam to get the payload?
UID Length: 7 bytes
Tag is NDEF formatted. Data area size = 128 bytes
output tag
NFC Tag - sP
UID 04 8D 71 9A 27 49 80
NDEF Message 1 record, 19 bytes
NDEF Record
TNF 0x1 Well Known
Type Length 0x10 16
Payload Length 0x0 0
Type 00 00 00 00 87 00 00 00 00 00 01 03 00 00 69 00 ....�.........i.
Payload
Record is 19 bytes
got message
Payload (HEX):
