PN532 emulated card not read by an iphone but can with Android
I am using the PN532 as an emulator using the emulate_tag_ndef.ino
example from arduino. I updated the emulate library according to another post (PN532 emulated card not read by an Android phone) to make it work, but it only works with Android. With iPhones I can only send up to 47 bytes, if succeeded. Here's how I set the PN532_COMMAND_TGINITASTARGET command:
uint8_t command[] = {
      PN532_COMMAND_TGINITASTARGET,
      0x05,                  // MODE: 0x04 = PICC only, 0x01 = Passive only (0x02 = DEP only)
      // MIFARE PARAMS
      0x04, 0x00,         // SENS_RES (seeeds studio set it to 0x04, nxp to 0x08)
      0x00, 0x00, 0x00,   // NFCID1t    (is set over sketch with setUID())
      0x20,               // SEL_RES    (0x20=Mifare DelFire, 0x60=custom)
      // FELICA PARAMS
      0x01, 0xFE,         // NFCID2t (8 bytes) https://github.com/adafruit/Adafruit-PN532/blob/master/Adafruit_PN532.cpp FeliCa NEEDS TO BEGIN WITH 0x01 0xFE!
      0x05, 0x01, 0x86,
      0x04, 0x02, 0x02,
      0x03, 0x00,         // PAD (8 bytes)
      0x4B, 0x02, 0x4F,
      0x49, 0x8A, 0x00,
      0xFF, 0xFF,         // System code (2 bytes)
      0x01, 0x01, 0x66,   // NFCID3t (10 bytes)
      0x6D, 0x01, 0x01, 0x10,
      0x02, 0x00, 0x00,
      0x00, // length of general bytes
      0x00  // length of historical bytes
Does anyone know how I can make the iPhone write to the PN532? I am using the NFC Tools app to write to it. I have tried other apps but without any luck
