PN532 help
I bought this nfc reader some days ago: http://es.aliexpress.com/item/Mini-PN532-NFC-RFID-Reader-Writer-Module-For-Arduino-Android-Phone/2038722238.html?recommendVersion=1 and yesterday I tried to use it. But I've been experiencing a lot of problemes with it.
first of all: all the pn532 drivers are the same? Which library should use?
I tried with an adafruit library and It's not working for me, It doesn't print nothing in the serial display :S
Help,
thank youu :smiley:
So how have you wired it up, schematic please.
And what code are you running, code please (in code tags use the </> icon )
The list of NXP NFC IC chip:
  • NXP PN531 Obsolete
  • NXP PN532 Most of NFC shield, if not all.
  • NXP PN533 (SCM SCL3711)
  • NXP PR533
  • NXP PN544
  • NXP PN65N
  • NXP PN65V10 Apple Iphone 6
  • NXP PN7120
http://forum.arduino.cc/index.php?topic=296382.msg2109685#msg2109685
NXP PN532 has 3 interfaces I2C, SPI, UART. The library and interface have to matched.
NXP PN532 with Arduino does not support complete NFC types.
sonnyyu:
  • NXP PR533
  • NXP PN544
  • NXP PN65N
  • NXP PN7120
NFC & YUN - #7 by sonnyyu - Arduino Yún - Arduino Forum
Depending on the interface the use of the wires change no? But can I use all of the intarfaces or this RFID supports only one of them?
Grumpy_Mike:
I have installed this adafruit library: Arduino Library | Adafruit PN532 RFID/NFC Breakout and Shield | Adafruit Learning System
I wired as the example code says and I am running mifare test, everything seems to be ok. :S
You did not address my questions.
So how have you wired it up.
and
schematic please.
yeehaaw:
You could wire PN532 with Arduino via one of them, and have to changed library match with it.
yeehaaw:
In the past there were two separate Arduino libraries for using the Adafruit NFC boards. One library supported the breakout over a SPI connection, and the other library supported the breakout or shield over an I2C connection. However both of these libraries have been merged into a single Arduino library, Adafruit-PN532.
The Adafruit PN532 library has the ability to read MiFare cards, including the hard-coded ID numbers, as well as authenticate and read/write EEPROM chunks. It can work with both the breakout and shield using either a SPI or I2C connection.
SPI or I2C connection , no UART support.
If you wired UART, you need different library.
Mifare Classic is not an NFC Forum compatible card. Mifare Classic 1K/4K is not NFC card!
  • NFC Forum Type 1 Broadcom Topaz
  • NFC Forum Type 2 Mifare Ultralight, Mifare Ultralight C
  • NFC Forum Type 3 Sony FeliCa
  • NFC Forum Type 4 Mifare Desfire (ev1/ev2), NXP SmartMX with JCOP
Mifare Classic is not an NFC Forum compatible card. It requires NXP's Crypto 1 support that is
only available in NXP reader ICs and crypto keys that are not published in NFC Forum specifications.
http://forum.arduino.cc/index.php?topic=296382.msg2068600#msg2068600
Grumpy_Mike:
and
schematic please.
SCK-2
MOSI-3
SS-4
MISO-5
GROUND-GROUND
5V-5V
#include <Adafruit_PN532.h>
#define SCK  (2)
#define MOSI (3)
#define SS   (4)
#define MISO (5)
Adafruit_PN532 nfc(SCK, MISO, MOSI, SS);
void setup(void) {
  Serial.println("Hello!");
  nfc.begin();
  uint32_t versiondata = nfc.getFirmwareVersion();
  if (! versiondata) {
    Serial.print("Didn't find PN53x board");
    while (1); // halt
  // Got ok data, print it out!
  Serial.print("Found chip PN5"); Serial.println((versiondata>>24) & 0xFF, HEX);
  Serial.print("Firmware ver. "); Serial.print((versiondata>>16) & 0xFF, DEC);
  Serial.print('.'); Serial.println((versiondata>>8) & 0xFF, DEC);
  // configure board to read RFID tags
  nfc.SAMConfig();
  Serial.println("Waiting for an ISO14443A Card ...");
void loop(void) {
  uint8_t success;
  uint8_t uid[] = { 0, 0, 0, 0, 0, 0, 0 };  // Buffer to store the returned UID
  uint8_t uidLength;                        // Length of the UID (4 or 7 bytes depending on ISO14443A card type)
  // Wait for an ISO14443A type cards (Mifare, etc.).  When one is found
  // 'uid' will be populated with the UID, and uidLength will indicate
  // if the uid is 4 bytes (Mifare Classic) or 7 bytes (Mifare Ultralight)
  success = nfc.readPassiveTargetID(PN532_MIFARE_ISO14443A, uid, &uidLength);
  if (success) {
    // Display some basic information about the card
    Serial.println("Found an ISO14443A card");
    Serial.print("  UID Length: ");Serial.print(uidLength, DEC);Serial.println(" bytes");
    Serial.print("  UID Value: ");
    nfc.PrintHex(uid, uidLength);
    Serial.println("");
    if (uidLength == 4)
      // We probably have a Mifare Classic card ...
      Serial.println("Seems to be a Mifare Classic card (4 byte UID)");
      // Now we need to try to authenticate it for read/write access
      // Try with the factory default KeyA: 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF
      Serial.println("Trying to authenticate block 4 with default KEYA value");
      uint8_t keya[6] = { 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF };
	  // Start with block 4 (the first block of sector 1) since sector 0
	  // contains the manufacturer data and it's probably better just
	  // to leave it alone unless you know what you're doing
      success = nfc.mifareclassic_AuthenticateBlock(uid, uidLength, 4, 0, keya);
      if (success)
        Serial.println("Sector 1 (Blocks 4..7) has been authenticated");
        uint8_t data[16];
        // If you want to write something to block 4 to test with, uncomment
		// the following line and this text should be read back in a minute
        // data = { 'a', 'd', 'a', 'f', 'r', 'u', 'i', 't', '.', 'c', 'o', 'm', 0, 0, 0, 0};
        // success = nfc.mifareclassic_WriteDataBlock (4, data);
        // Try to read the contents of block 4
        success = nfc.mifareclassic_ReadDataBlock(4, data);
        if (success)
          // Data seems to have been read ... spit it out
          Serial.println("Reading Block 4:");
          nfc.PrintHexChar(data, 16);
          Serial.println("");
          // Wait a bit before reading the card again
          Serial.println("Ooops ... unable to read the requested block.  Try another key?");
        Serial.println("Ooops ... authentication failed: Try another key?");
    if (uidLength == 7)
      // We probably have a Mifare Ultralight card ...
      Serial.println("Seems to be a Mifare Ultralight tag (7 byte UID)");
      // Try to read the first general-purpose user page (#4)
      Serial.println("Reading page 4");
      uint8_t data[32];
      success = nfc.mifareultralight_ReadPage (4, data);
      if (success)
        nfc.PrintHexChar(data, 4);
        Serial.println("");
        Serial.println("Ooops ... unable to read the requested page!?");
Should I change the programmer to arduinoISP?
up :frowning:
Waiting for a schematic.
Grumpy_Mike:
Here you have it: Screenshot - b6adeb35208bee7f1a9d73ba3ba4c46e - Gyazo
Very funny. :frowning:
now :slight_smile: :slight_smile: There isn't PN532 board in Fritzing so I used this board. I thin that is clear.
Hello guys, i know this is a very old post.
i connected my PN532 as specified in the PN532 manual, everything works perfect.reads any ISO14443a Cards tags, and NFC Phones.
I connected my PN532 using SPI and didn't have any issues at all, only issues i had was with the library but that was about location placement, other then that no issues
My only issue i have is that I want it to read ISO14443b cards. according to the manual it can, but there is no library and there is no support for ISO14443b cards. i did find this link with useful information, but once again another dead end. Can't read ISO14443B TAG · Issue #397 · nfc-tools/libnfc · GitHub
Hopefully someone here can point me to the right direction...or if anyone need help on connection or configuring please message me.
thnx
