PN532 not responding
Dear all I am using PN532 and it cannot be read by the arduino i used i2c communication with the following connection
pin 2 to IRq
pin3 to Reset
scl to A5
SDA to A4
I used "realmifareclassic" from "Adafruit_PN532.h"
I made my changes highliting the following
//#define PN532_SCK  (2)
//#define PN532_MOSI (3)
//#define PN532_SS   (4)
//#define PN532_MISO (5)
//Adafruit_PN532 nfc(PN532_SCK, PN532_MISO, PN532_MOSI, PN532_SS);
and unhighlighting the following
#define PN532_IRQ   (2)
#define PN532_RESET (3)  // Not connected by default on the NFC Shield
Adafruit_PN532 nfc(PN532_IRQ, PN532_RESET);
I don't know serial monitor always printing "pn53# not found"
so someone please help me with this issue
Thanks in advance
Do you have the jumpers set fot I2C?
Do you have pull-up resistors of SCL, SDA
no I don't have pull up resistors
i will purchase it, thanks, I will test and inform you
still no result, I am using version 3, could anbody help?
Do you mean version 1.3?
Which arduino board are you using?
You need to post your full code
I want to thank I solved the issue It was about wiring issue that I didn't realize except at a late time... thanks for your time
