PN532 slow and libraries question
My PN532 runs the following code;
setup...
#include <SPI.h>
#include <PN532_SPI.h>
#include "PN532.h"
with the loop being....
nfc.begin();
  nfc.setPassiveActivationRetries(0x01);
  nfc.SAMConfig();
  uint32_t versiondata = nfc.getFirmwareVersion();
  if (! versiondata) {
    Serial.print("Didn't find PN53x board");
    while (1); // halt
  uint8_t uid[] = { 0, 0, 0, 0, 0, 0, 0 };  // Buffer to store the returned UID
  uint8_t uidLength;                        // Length of the UID (4 or 7 bytes depending on ISO14443A card type)
  success = nfc.readPassiveTargetID(PN532_MIFARE_ISO14443A, &uid[0], &uidLength);
  if (success) {
    Serial.println("Found a card!");
    for (uint8_t i = 0; i < uidLength; i++)
      // Serial.print(" 0x");Serial.print(uid[i], HEX);
It runs and I have seen a thread that suggests modifying the PN532.h file to reduce the timeout and help speed .....
bool readPassiveTargetID(uint8_t cardbaudrate, uint8_t * uid, uint8_t * uidLength, uint16_t timeout = 0); //timeout 0 means no timeout - will block forever.
This seems to have an affect but from my setup, how do i know I am changing the correct file? I am not sure what #include "PN532.h" refers to?
I have Adafruit PN532 library folders and Adafruit PN532 library folders and I am not sure what is being used?
In addition, I have seen other sketches that put .....
nfc.begin();
  nfc.SAMConfig();
All in Setup but if I do that the PN532 isnt recognised.
Some progress. In the sketch;
as it states manages the retries before giving up to find a card and can be set very low.
In the PN532.h the line.....
seems to work down to around 50ms.
Both have an effect
It still seems to slow the rest of the program a bit and if I comment the code out I can see a reasonable gain.
As I am using the V3 Elechouse PN532, does anyone know if this is the latest library?
Pn532 library
I cant see anything else in the loop PN code that would slow it down.
    while (1); // halt
  if (success) {
You should not be editing the library. The timeout is a parameter you pass when you call the function and if you don't supply it, it defaults to 0 which mean forever
//success = nfc.readPassiveTargetID(PN532_MIFARE_ISO14443A, &uid[0], &uidLength);
success = nfc.readPassiveTargetID(PN532_MIFARE_ISO14443A, &uid[0], &uidLength, 100); // 100 msec timeout
