i'm looking for a component (motor?) that outputs air (like a small reverse vacuum-cleaner) if it is triggered. does anybody know of anything like this exists?
sorry for the terrible explanation – if i'd know better keywords i could probably google
hehe, thanks.. just started to ask you. i have absolutely no clue about this stuff – have you got any experience with vane pumps? or possibly a blind guess pointing me in the right direction as for what to buy?
bennii:
Possibly an old refrigerator pump, they are normally dicplacement pumps but can be had cheaply, if you can find an obliging scrapyard, EU regs makes this difficult these days.
If you can find a suitable pressure regulator an old car tyre may do, i use one for my airbrush when its late.
One of those matress pumps would probably work but it will be noiser than your flute
jremington:
The hard problem will be to have the Arduino open and close the holes or valves in the instrument.
i was considering a "blechbuegelmagnet" or "hubmagnet" (don't know the english term) as such:
i suppose it'd be lots and lots of trying around, how ever the pumping-part is currently my main concern. i'd be gracious for any further ideas and hints
Boardburner2:
oh jee.. i'd have no idea how to get something as such to work to my desire. so – am i getting you right, that it'll be hard to find a prebuilt part for the pumping?
Boardburner2:
Solenoid works, i have seen this done on a clarinet.
I suspect that some work would be needed to get rid of the rather annoying clicks though.
that sounds incredible! glad to heat that it had worked for you.. googling "solenoid" doesn't make me all too smart. you possibly have a picture (or link) of the particular part that you used?
All kinds options there.
Likely will need to have a transistor between Arduino pin and solenoid coil to open the valve as Arduino output is only capable of 25-30mA from a 5V source.
bennii:
I did not make it.
A clarinet already has pads to cover the holes so an ordinary solenoid to press the keys was all that was required i think.
You need about 10 litres per min at about 1 psi i guess.
Looking around that's fairly tricky to achieve, most sample pumps are diaphragm and .5 l/s.
Maybe a servo pushing an arm into the airflow to deflect it away from the flute opening is all that is needed.
No clicking that way, just a little whir as the servo moves a few degrees.
Boardburner2:
The holes under your three middle fingers on each hand have no pads on a clarinet or flute. That's because the plebian clarinet and flute players can't afford as many pads as their saxophone overlords can.
For an air solenoid I'd suggest the mini ones like those used in coffee machines. If you do go with an industrial air solenoid like those that CrossRoads linked make sure it's a direct acting ("standing up") rather than pilot operated ("laying down"). The latter has a minimum air pressure it will work with and that pressure will be much higher than the ~1PSI you'll want.
