Hi everyone. So im making a touch screen button for a project using a iLi9488. Everything is working fine so far, the problem is i suck at logic and syntax. So ive successfully managed to get the screen working and got the button on the screen too. I dont know what to do in order to move the image into the desired area of the screen i want(Middle). Currently the button is stuck on the left top corner.
as for the program im using here it is:
#include <PNGdec.h>// Include the PNG decoder library
#include "green.h"
PNG png; //PNG decoder instance
#define MAX_IMAGE_WIDTH 500 // 240 was before // for new image 240 isn't working but 700 is
int16_t xpos = 0;
int16_t ypos = 0;
#include "SPI.h"
#include <TFT_eSPI.h> // Hardware-specific library
TFT_eSPI tft = TFT_eSPI(); // Invoke custom library
Serial.println("\n\n Using the PNGdec library");
tft.setRotation(1);
// Initialise the TFT
tft.begin();
tft.fillScreen(TFT_BLACK); // command for lcd screen
//tft.setCursor(download_png_Greeb_start_removebg_preview, 120, 200);
int x = 60;
int y = 10;
Serial.println("\r\nInitialisation done."); // put your setup code here, to run once:
int16_t rc = png.openFLASH((uint8_t *)download_png_Greeb_start_removebg_preview, sizeof(download_png_Greeb_start_removebg_preview), pngDraw);
if (rc == PNG_SUCCESS) {
Serial.println("Successfully png file");
Serial.printf("image specs: (%d x %d), %d bpp, pixel type: %d\n", png.getWidth(), png.getHeight(), png.getBpp(), png.getPixelType());
tft.startWrite();
uint32_t dt = millis();
rc = png.decode(NULL, 0);
Serial.print(millis() - dt); Serial.println("ms");
tft.endWrite();
// png.close(); // not needed for memory->memory decode
delay(000);
void pngDraw(PNGDRAW *pDraw) {
uint16_t lineBuffer[MAX_IMAGE_WIDTH];
png.getLineAsRGB565(pDraw, lineBuffer, PNG_RGB565_BIG_ENDIAN, 0xffffffff);
tft.pushImage(xpos, ypos + pDraw->y, pDraw->iWidth, 1, lineBuffer); // y
also i havent included the array which is being used for conversion of the PNGPreformatted text
