hi,
i want show in my display the png image stored in sd card, i used PNGDEC and the examples,
it works loading from Flash, LittleFS, but not from SD. It seems the PNG is loaded but no matter what I change, I always get this strange image on the Lcd.
This is the code, modified from example "LittleFS_PNG".
// This example if for processors with LittleFS capability (e.g. RP2040,
// ESP32, ESP8266). It renders a png file that is stored in LittleFS
// using the PNGdec library (available via library manager).
// The test image is in the sketch "data" folder (press Ctrl+K to see it).
// You must upload the image to LittleFS using the Arduino IDE Tools Data
// Upload menu option (you may need to install extra tools for that).
// Don't forget to use the Arduino IDE Tools menu to allocate a LittleFS
// memory partition before uploading the sketch and data!
#include <LittleFS.h>
#define FileSys LittleFS
//#include <FS.h>
#include <SD.h>
// Include the PNG decoder library
#include <PNGdec.h>
PNG png;
#define MAX_IMAGE_WIDTH 120// Adjust for your images
int16_t xpos = 0;
int16_t ypos = 0;
// Include the TFT library https://github.com/Bodmer/TFT_eSPI
#include "SPI.h"
#include <TFT_eSPI.h> // Hardware-specific library
TFT_eSPI tft = TFT_eSPI(); // Invoke custom library
// Setup
Serial.println("\n\n Using the PNGdec library");
/* // Initialise FS
if (!FileSys.begin()) {
Serial.println("LittleFS initialisation failed!");
wh*ile (1) yield(); // Stay here twiddling thumbs waiting
// Initialise the TFT
tft.begin();
tft.fillScreen(TFT_BLACK);
Serial.println("\r\nInitialisation done.");
while (!SD.begin(5)) {
Serial.println("Unable to access SD Card");
tft.println("Unable to access SD Card");
File pngfile;
void * pngOpen(const char *filename, int32_t *size) {
Serial.printf("Attempting to open %s\n", filename);
pngfile = SD.open(filename);
*size = pngfile.size();
return &pngfile;
/// Serial.printf("Attempting to open %s\n", filename);
/// pngfile = FileSys.open(filename, "r");
/// *size = pngfile.size();
/// return &pngfile;
void pngClose(void *handle) {
File pngfile = *((File*)handle);
if (pngfile) pngfile.close();
int32_t pngRead(PNGFILE *page, uint8_t *buffer, int32_t length) {
if (!pngfile) return 0;
page = page; // Avoid warning
return pngfile.read(buffer, length);
int32_t pngSeek(PNGFILE *page, int32_t position) {
return pngfile.seek(position);
//=========================================v==========================================
// pngDraw
// This next function will be called during decoding of the png file to
// render each image line to the TFT. If you use a different TFT library
// you will need to adapt this function to suit.
// Callback function to draw pixels to the display
void pngDraw(PNGDRAW *pDraw) {
uint16_t lineBuffer[MAX_IMAGE_WIDTH];
png.getLineAsRGB565(pDraw, lineBuffer, PNG_RGB565_BIG_ENDIAN, 0xffffffff);
tft.pushImage(xpos, ypos + pDraw->y, pDraw->iWidth, 1, lineBuffer);
// Loop
// Scan LittleFS and load any *.png files
// File root = LittleFS.open("/", "r");
// while (File file = root.openNextFile()) {
// String strname = file.name();
String strname = "/EagleEye.png"; ///+ strname;
// Serial.println(file.name());
// // If it is not a directory and filename ends in .png then load it
// if (!file.isDirectory() && strname.endsWith(".png")) {
// // Pass support callback function names to library
int16_t rc = png.open(strname.c_str(), pngOpen, pngClose, pngRead, pngSeek, pngDraw);
if (rc == PNG_SUCCESS) {
tft.startWrite();
Serial.printf("image specs: (%d x %d), %d bpp, pixel type: %d\n", png.getWidth(), png.getHeight(), png.getBpp(), png.getPixelType());
uint32_t dt = millis();
if (png.getWidth() > MAX_IMAGE_WIDTH) {
Serial.println("Image too wide for allocated line buffer size!");
else {
rc = png.decode(NULL, 0);
png.close();
tft.endWrite();
// How long did rendering take...
Serial.print(millis()-dt); Serial.println("ms");
// delay(3000);
// tft.fillScreen(random(0x10000));
The serial monitor says
" Using the PNGdec library
Attempting to open /EagleEye.png
image specs: (120 x 120), 8 bpp, pixel type: 6"
I tired several Png files, this one is from an example (littleFS) and if I load the same file from LittlFS it works.
