PNP transistor 2n4123
Would it be possible to create a login level converter/ shifter with PNP transistor 2N4123? I am aware of a schematic using NPN transistors bit I'm not sure about PNP. I ask because it's what I have on hand from salvaging parts from dead electronics. Data sheet attached. Working on a project with my son and it requires a level shifter for i2c communication.
2N4123-D (1).PDF (116 KB)
If the circuits have common ground and differing (positive) supply voltages, an NPN open collector circuit
can be used. A PNP is no use.
A 2N4123 is a NPN transistor not PNP.
Excellent, problem solved! Unless of course the device number is incorrect and it really is a PNP.
Face palm.....
I blame dyslexic keyboards myself, my work keyboard does this to me at least once a day.
Tom... :slight_smile:
I got my data sheets mixed wile vigorously salvaging parts from old circuit boards. It was a wild day. I woke the following day with a resistor stuck to my cheek because I passed out in a pile of loose parts. Probably knocked out because of fume inhalation. Who knows what those ancient boards were mode of. Some smelled like cat pee.
GotZaped:
I got my data sheets mixed wile vigorously salvaging parts from old circuit boards. It was a wild day. I woke the fallowing day with a resistor stuck to my cheek because I passed out in a pile of loose parts. Probably knocked out because of fume inhalation. Who knows what those ancient boards were mode of. Some smelled like cat pee.
"Oh I love the smell of hot solder flux in the morning.." :slight_smile: :slight_smile: :slight_smile:
