PNP transistor not working
When the power supply is give to the connector means the PNP transistor have to switch and +5V is given to the PIC controller's pin for reference.
But when i connected the PNP transistor means I can't get any output from the regulator.If I removed the PNP transistor means i can get +5V from the regulator.R4 is resistor is connected to ground,which used for PIC power supply.
This regulator circuit should active when the power supply is given to it.
Your circuit is completely illegible, please post one at a readable resolution.
I can hardly see anything, but I think that's not even a PNP in that diagram
