hello
i have just two questions about the pocket piano
im having just a little bit of trouble with the schematic
i don't know where to connect the two capacitors located near the multiplexer chips (vcc and grd)
(are they connected to pins on the capacitors or to the arduino)
there is also one located near the mcp 4921 chip
and secondly
where the sting of three potentiometers there is a vcc out and a pot 1
(i am wondering if that pot 1 is a typo and is suppose to be a GRD)
The capacitors are connected across the + and - as close to the chip as you can. I see that C10 is out there in la-la land, and should be for the bottom multiplexer.
The pot_1 designation appears to be a typo and should go be labeled "ground"
