i want to make something that can mesure ( at the cm or inch ) A point a to point B. But i can't use any ultrasonic sensor because there can be a wall between . I want to press a button on point A and walk over to B and then have the distance but the distance is between ( 20cm and 9m ).
andreeke:
If there is a wall between the two points how are you going to walk from one to the other?
Get a floor plan of the house, to scale. Carefully mark A and B on the plan, and measure the distance between them. Scale up the result according to the plan scale.
The modus operandi will be : the first push on a button is the point of zero a red light is lighting up and from the moment you are at 5 meters there is a green light lightning up. So the point zero is the middle of the circle.
The biggest problem is that the "thing" has to remember where point zero is.
I was think at a kind of gps with high precision.
The good thing is you don't care about your absolute place in the world, only about your location within the house.
I think the best option is to mimic GPS. Place a few (at least three) radio beacons in the home. Get a device that can triangulate it's location to those three beacons. As long as you don't move those beacons you can accurately locate yourself within the house, relative to an arbitrarily chosen zero point.
I recall having seen such things on the forum, but can't remember the name. Maybe people with better memory do.
