pointer array to many 2d boolean arrays
Hello guys, I´m struggling to make a pointer to several 2d boolean arrays.
boolean array0[2][2] = {{0,0},{0,0}};
boolean array1[3][3] = {{0,0,0},{0,1,0},{0,0,0}};
boolean array2[2][2] = {{0,0},{0,0}};
boolean *arrays[3] = {&array0[0][0], &array1[0][0], &array2[0][0] };
boolean **arraySelect;
arraySelect = &arrays[1];
return arraySelect[1][1];   <----- this line does not return 1 , it returns a random number
Any advise ? Where I made a mistake?
Thank you!
This is the address of the second pointer in the list of pointers so it is a pointer to a pointer to array1.
The first index picks up the address of array2 (the pointer after the second pointer in the list).
The second index gives your the second boolean in array2;
To get index [1][1] of array1 you will have to do the indexing math yourself:
return arrays[1][1*3+1];
This gives you the second boolean in the second row of booleans in array1. You need to know the number of elements in a row of your array to calculate the answer (note the '3' in the indexing math). Once you store the address of the array as a pointer it no longer carries dimension information. You could put in a parallel array:
const byte row_sizes[3] = {2, 3, 2};
return arrays[1][1*row_sizes[1]+1];
Hi johnwasser.
Clear explanation!! I understood the math.
The good news is that, in my original code , all arrays have the same number of row size.
So,maybe I can do the math without the "row_sizes" support.
I´ll try it at home and update here with results.
Thank you !
Only works if each array has the same element size, which is to say, if each array is an array of arrays of 3 booleans.
boolean array0[2][3] = {{0,0},{0,0}};
boolean array2[2][3] = {{0,0},{0,0}};
boolean test1 = array0[0][0];
boolean *test2 = array0[0];
boolean (*test3)[3] = array0;
boolean (*arrays[])[3] = {array0, array1, array2 };
boolean getAnElement = arrays[0][0][0];
Maybe a tad beside the point but an array of boolean is rather memory in-efficient. Being that a boolean also takes up 1 byte, where 8 bits are available per byte and can easily be accessed individually.
Hi guys .
johnwasser: YES , it worked like a breeze. Thank you!
PaulMurrayCbr : YES , it worked like a breeze too. Thank you!
Deva_Rishi: YES , followed your advice and changed my arrays to byte. Thank you!
Made my day ! thank you for the knowledge!
