Pointer assignment
Hello
I was given an assignment by my teacher to help us with pointers and functions before our next test. The problem is that I am having huge issues understanding these topics.
I have attached the assignment and all that I have coded out so far. Any help, explanations, links to tutorials would be greatly appreciated.
Thank you.
void explainProgram(void) {
  Serial.print("--Amperage calculator--\n\n");
  Serial.print("This program calculates the amperage\nthrough a resistor given voltage and resistance.\n\n");
void getValues(float *ohms, float *volts) {
float doCalculations(float res, float *volt) {
void displayAnswer(float amps) {
  explainProgram();
Assignment1.pdf (51.3 KB)
do u have a schematic of what u are doing.. kinda tuff otherwise......
backwoodsjack:
Here you go:
V(+) ----////---- V(-)
You must use the following prototypes: (Do not alter their parameters)
void explainProgram(void);
void getValues(float *ohms, float *volts);
float doCalculations(float res, float volt);
void displayAnswer(float amps);
You have at least the following variables:
float resistor, voltage, current;
No global variables are allowed.
Interesting. The problem is in the last line.
If it's a school assignment, you should do more before asking for help here, though. What you posted isn't even an attempt.
aarg:
This is because I don't know how or where I should approach this assignment.
