pointer question.
Pointers, seeing there's only 2k of RAM, are they only 2 bytes long or something like 4 bytes?
Thanks!
-jim lee
Memory is single bytes.
2KB (2048) of SRAM in an Atmega 328
A pointer will have a "type"
You need two bytes to store a pointer.
2 bytes to store. Thanks!
if you have a serial console, the best is to print sizeof(void*)to know for sure.
sonyhome:
If you ever have something static like this you would like to prove, you can get the compiler to do it for you, rather than having to upload a whole sketch.
This code will fail to compile if sizeof(void*) is not 2.
If it compiles, then you know your assumption was correct.
bool pointer_size[ sizeof(void*) == 2 ? 1 : -1 ];
@pYro_65: Slick! I would have just printed out the sizeof(void *).
