main string buffer w/ max size of 150 char in ram
a bunch of small strings in PROGMEM
a lookup table of pointers to those strings in PROGMEM
what I want to do is use the strings in PROGMEM to build the main buffer without over running it.
The issue I'm having is getting the length of a particular string in PROGMEM
I have no trouble getting the right string from the lookup table but I'm unable to get the length of the string. Pointers have always given me a headache. I understand they're are addresses to where the data is stored. Its the way they are access has always been a pain for me.
I have sizeof (string_lookuptable[i]) which is the address of where the string is stored . what i need though is the length of the actual string that is being pointed to. I get confused with the redirection * and &. format.
So how should the syntax look like to get the length of the actual string?
`#define BUFF_SIZE 150
const char string_0[] PROGMEM = "HELLO"; // "HELLO" etc are strings to store - change to suit.
const char string_1[] PROGMEM = "This space available for advertising";
const char string_2[] PROGMEM = "Single male seeks single female ) for LTR";
const char string_3[] PROGMEM = "Don't stay a stranger my Lady! ";
const char string_4[] PROGMEM = "Bye Bye";
const char string_5[] PROGMEM = "Hi!";
const char string_6[] PROGMEM = "Thank You";
const char string_7[] PROGMEM = "What do you think of my message board? ";
const char string_8[] PROGMEM = "Did you base your career choice on Star Trek ?";
const char string_9[] PROGMEM = "Are you a fan of ";
const char string_10[] PROGMEM = "Dr. Who, Stargate SG-1, Stargate Alantis, Bybalon 5";
// Then set up a table to refer to your strings.
const char * const string_table[] PROGMEM = {string_0, string_1, string_2, string_3, string_4, string_5,
string_6, string_7, string_8, string_9, string_10};
char Message[BUF_SIZE] = "Hello world! how are you? ";
void assemblemess()
if( sizeof(Message) + sizeof(&string_table[j])< BUF_SIZE-1)
addProgStr( (const char *) pgm_read_word (&string_table[j]) );
storedphrase = false; // set overrun flag
void addProgStr (const char * str)
if (!str)
return;
while ((ch = pgm_read_byte(str++)))
Message[i++] = ch;
Message[i] = '\0';
} // end of printProgStr
`Use code tags to format code for the forum`
Here is some of the code
I use the if statement to check to see if there is enough room for the string I want to add.
As has been pointed out, you want to use strlen, not sizeof. sizeof gives you the size of the array (in bytes), not the length of the string contained in the array.
Also be careful, string_table is stored in PROGMEM, so you need to properly access it.
void assemblemess()
if ( strlen(Message) + strlen_P(pgm_read_ptr(&string_table[j])) < BUF_SIZE - 1)
addProgStr( (const char *) pgm_read_ptr(&string_table[j]) );
