Pointer to specific instance of class/object in an array
Please correct me if I’m using the incorrect lingo,
I have an array of custom objects and I need to access a method in one of the objects. Now, while I can access it via it’s array index, I’d like to use a friendly name so my code is more readable. Can I create a pointer to that specific object and what’s the best way to do so without using too much more RAM?
class PressureSensor{
  public:
    PressureSensor(int _startingValue){
      value = _startingValue;
    void getValue(){
      return value;
    void setValue(int _value){
      value = _value;
  private:
    int value;
PressureSensor pSensors[3] = {
  PressureSensor(50),
  PressureSensor(100),
  PressureSensor(150),
Instead of using
pSensors[1].getValue();
I’d like to use
highPressure.getValue();
Where do you define your variable 'highPressure'?
highPressure is supposed to be a pointer to pSensors[1]. I don’t know where/how I should define it.
First, you have to fix this:
   void getValue(){
      return value;
You claim that getValue() returns no value (that's what 'void' means), then you try to return a value.
Then something like:
  PressureSensor *highPressure = pSensors + 1;
  int p = highPressure->getValue();
Thanks!
This is what I've been trying to figure out.
m_elias:
Thanks!
This is what I’ve been trying to figure out.
Or you could do as real programmers do:
  PressureSensor *pSensor = pSensors[1];
PaulS:
Perhaps real programmers who don't know how to use pointers. That should be:
PressureSensor *pSensor = &pSensors[1];
gfvalvo:
My bad for assuming that everyone followed my naming convention of using a lower case p in the name of all variables that are pointers or arrays of pointers. I see now that pSensors is not an array of pointers, so the address of operator is indeed required.
