Hello,
[I am thinking of automating a supermarket queuing mechanism by implementing a Poisson queue distribution which will be in synchronised with other queues.
For instance 5-10 persons per queue on 1 counter. At each counter, an LCD will display the time taken per customer based on that corresponding queue.]
I am searching help for writing the code.
Problem: I have a supermarket whereby the clients need to search and then select the shortest queue. Suppose there are 4 queues such that each queue contains around 5-10 persons. I am thinking of automating this search by implementing a queuing mechanism (for e.g. Poisson Distribution). The queuing mechanism can be then synchronized with other queues at each counter. An LCD (as a display mean) can be used to inform the clients which queue they should take.
So, I want to know if this is possible.
