Pokusajizradezadatka
#include <avr/io.h>
#include <avr/interrupt.h>
const unsigned char cifre[] = {
0x05,0xdd, 0x46, 0x54, 0x9c, 0x34, 0x24, 0x5d, 0x04, 0x14
unsigned char DISP_BAFER[4] ={0xff,0xff,0xff,cifre[0]};
const unsigned char minus = 0xfe;
unsigned char ukljuceno = 1;
volatile unsigned long ms = 0;
volatile unsigned char disp = 3;
volatile int number = 0;
ISR(TIMER0_COMPRA_vect){
if(++disp > 3)
disp = 0;
PORTB = ~(1 << (3-disp));
PORTD = DISP_BAFER[disp];
ms++;
ISR(PCINT1_vect)
switch((~PINC) & 0x0a)
case 0x02:
ukljuceno = 1;
number--;
case 0x08:
ukljuceno = 0;
number++;
int main(){
int pom1, pom2, mi=0,zero=0;
char i;
unsigned long t0;
DDRB = 0x0f;
DDRC = 0x00;
DDRD = 0xff;
PCICR = (1<<PCIE1);
PCMSK1 = 0x0a;
TCCR0A = 0x02;
TCCR0B = 0x03;
OCR0A = 249;
TIMSK0 = 0x02;
sei();
while(1) {
t0 = ms;
while((ms-t0)<100);
pom1 = number;
if(pom1<0){
pom1*= (-1);
for(i = 3; i > 0; i--){
pom2= pom1%10;
DISP_BAFER[i] = cifre[pom2];
pom1/=10;
if(pom2!=0){
mi = i;
zero =i-1;
DISP_BAFER[mi-1] = minus;
mi = 0;
for(i=0;i<zero;i++){
DISP_BAFER[i] = 0xff;
} else if(pom1!=0){
for(i = 3; i>= 0; i--){
pom2=pom1%10;
pom1/=10;
if(pom2!=0){
zero = i;
for(i = 0; i<zero;i++){
} else{
  DISP_BAFER[3] = cifre[0];
  DISP_BAFER[2] = 0xff;
  DISP_BAFER[1] = 0xff;
  DISP_BAFER[0] = 0xff;
return 0;
This is no good as a tutorial,if you don’t explain what it’s meant to do…!
#include <avr/io.h>
if(++disp > 3)
disp = 0;
ms++;
ISR(PCINT1_vect)
case 0x02:
ukljuceno = 1;
number--;
case 0x08:
ukljuceno = 0;
number++;
int main(){
char i;
unsigned long t0;
DDRB = 0x0f;
DDRC = 0x00;
DDRD = 0xff;
PCICR = (1<<PCIE1);
PCMSK1 = 0x0a;
TCCR0A = 0x02;
TCCR0B = 0x03;
OCR0A = 249;
TIMSK0 = 0x02;
sei();
while(1) {
t0 = ms;
while((ms-t0)<100);
pom1 = number;
if(pom1<0){
pom1*= (-1);
pom2= pom1%10;
pom1/=10;
if(pom2!=0){
mi = i;
zero =i-1;
mi = 0;
} else if(pom1!=0){
pom2=pom1%10;
pom1/=10;
if(pom2!=0){
zero = i;
} else{
return 0;
@kiseli99 I suggest that you change the title of the topic to English if you want help in the English section of the forum
please edit your post, select the code part and press the </> icon in the tool bar to mark it as code. (also make sure you indented the code in the IDE before copying, that's done by pressing ctrlT on a PC or cmdT on a Mac)
a bit of information would go a long way and if you have a question then write it up... (please use English on the English forums)
