I'm looking to generate two fairly high voltage (45V) DC outputs from the Arduino, I've managed to get up to +45 VDC using this Arduino inductor circuit - Arduino Playground - RegulatedPositiveVoltageBooster however I also want to generate at the same time a -45V output.
Most solutions I've seen using op-amps to invert the voltage have a limit of -12V of so due to the limitations of the IC.
Anyone have any idea how I might invert this +45V output to a -45V output?
Simple. Charge up a capacitor to +45v then connect the positive end of the capacitor to your ground. The negative end of that capacitor is now at -45v.
It will look very much like that example except two switches are required, to switch both ends of the capacitor simultaneously. You can probably even run it synchronously with the main 45v booster and save a few circuit elements.
This kind of approach is often called a "voltage doubler."
So would you end up constantly charging/discharging the 'reverse' capacitor to generate the -45V then? Would it provide a stable -45V or would you need some regulator to smooth out any voltage spikes?
Switched capacitor supplies are not very efficient above milli-amp levels, and I've never heard
of a 45V switched-cap IC!
XY problem suspected - perhaps the OP can explain what they are actually trying to achieve?
Is there signifcant power? Does the voltage need to be controllable analog and/or PWM?
MarkT:
Hi MarkT, it's for a university biology module on muscle simulation. To get any contraction you need a voltage in the 40V range, however to avoid any redness you need to balance out two electrode placements at the same positive/negative voltage roughly. Thus the need to invert the +45V I'm getting to drive a periodic negative voltage 'ping' to a muscle group.
Going to give the switched capacitor a try, but ideally I'd love the same inductor/capacitor circuit I have to boost the Arduino 5V to 45V to give a -45V output too.
