I am throwing together my first Arduino project and I am rusty to C/C++ so I do not know where to start or get the information for this task. Basically I want to poll a force-sensing resistor which is connected to my board and based on the weight I will light up certain LEDs. (The part I have trouble with is polling the sensor)
I am not sure what your problem is.
AnalogRead(pin) will read the value of the sensor, if you connect it to the analogue input and wire a pull up resistor from the input to +5V.
Thats what I needed to know. Thanks. I do not know where to get this info. I've been doing Java/Python and its been years since ive worked with C. Completely new to Arduinos.
You want to setup the FSR in a voltage divider configuration, then read the voltage drop across a known resistor value. You can invert this to approximate force. We wrote a whole tutorial on doing this with an FSR here:
