polling with single encoder input?
i am trying to use this 720 count encoder to start counting at the Z index and when it gets to 720 start counting from 0 again. only need one way so i assume only one phase is needed?
right now it is reading either 0 or 1 on the serial monitor depending on position
the index does seem to be working good though on the start
const int encoder = 2;
const int index   = 3;
int timing;
    pinMode(encoder, INPUT_PULLUP);
    pinMode(index,   INPUT_PULLUP);
    while (digitalRead(index)==HIGH){};   //do nothing untill the index goes low
   timing=digitalRead(encoder);
   if (index==LOW   ) timing  =1;   //start
   if (encoder==LOW ) timing +=1;   //add 1 degree to timing
   if (encoder==HIGH){}             //do nothing
   if (index==LOW   ) timing  =0;   //when index is low then start counting from 1 again on timing
   Serial.print(timing);
   Serial.println(" degrees");
You are not reading the encoder input. You are comparing the pin number (3?) to LOW (0).
Try this way:
const byte EncoderDIPin = 2;
const byte IndexDIPin   = 3;
int timing = 0;
  Serial.begin(1156200);
  while (!Serial) ; // Needed for Leonardo or Micro
  pinMode(EncoderDIPin, INPUT_PULLUP);
  pinMode(IndexDIPin,   INPUT_PULLUP);
  while (digitalRead(IndexDIPin) == HIGH) {}; //do nothing untill the index goes low
  boolean encoderState = digitalRead(EncoderDIPin) == LOW;
  static byte oldEncoderState = true;
  boolean indexState = digitalRead(IndexDIPin) == LOW;
  static byte oldIndexState = HIGH;
  // If the 'index' signal has just gone active (LOW) reset the timer counter
  if (indexState != oldIndexState)
    oldIndexState = indexState;
    if (indexState)
      timing = 0;
  // If the encoder signal has just gone active (LOW) increment the timer counter
  if (encoderState != oldEncoderState)
    oldEncoderState = encoderState;
    if (encoderState)
      timing++;
  //  Display the position each second
  static unsigned long displayTimer = 0;
  if (millis() - displayTimer >= 1000)
    displayTimer = millis();
awesome! it works great
strangly i can get up to about 750 counts on a 720 encoder?
i wonder if this is reading some bounce on the counts at low (hand) speed
it would take a lot more code to input the B phase and only count one way?
time to study this ....
turbothis:
Probably so. With an encoder you can usually put a small cap (like 0.1uF plus or minus a huge window) across the pin and the center pin and filter out the bounce that way instead of having to code around it.
"across the pin and the center pin "
so on the A phase and where? lol
for learning sake
if there was a piece of code that was like
if A phase goes high, followed by B phase goes high
then do function
if A phase goes high, followed by B phase going low
then ignore function
this would make a one way counter right?
also is there a way to have the print function only print if something new happens? or is it always running?
turbothis:
You got three pins on the encoder. A pin, a B pin, and the third pin usually goes to ground. Sometimes it goes to hot, but usually goes to ground. So 99% chance I mean between the A pin and ground. And another on the B pin and ground if you want to read it.
turbothis:
for learning sake
then do function
You could do that by recording the value from millis so at any transition you can see how long it has been since the last.
But you don't need to do that.
Look at how the gray code on an encoder looks. All you need to do is read the other pin. If the two pins match then you're going one way and if it doesn't then you're going the other way. A quick bit of experimentation with your particular encoder will help you determine which way is which. You just need to know if you are the leading or the lagging pin, and to do that all you need to know is if the other pin beat you to this state.
Adding debounce to the encoder signal:
  unsigned long currentMillis = milis();
    if (indexState)
      timing = 0;
  static unsigned long previousEncoderChangeTime = 0;
  if (encoderState != oldEncoderState && currentMillis - previousEncoderChangeTime > 10)
    previousEncoderChangeTime = currentTime;
    if (encoderState)
      timing++;
  if (mcurrentMillis - displayTimer >= 1000)
    displayTimer = currentMillis;
It looks like you want a readout of degrees, but your approach is prone to error if the input isn’t always moving in the positive direction.
I’d have thought just do full quadrature encoding. If you get back to Z and the count isn’t +360degrees or -360 degrees then you know there is a malfunction (ie you can have built in error spotting).
Also, I wonder if you should be using interrupts ?? I could be wrong here, but I think of interrupts allowing you to have other code doing stuff while making sure you don’t miss any encoder movement. Without interrupts you need a better understanding of the code timings to make sure it is reliable.
Here is some interrupt code for quadrature if you want to try it. Add you own code for Zero on Z, or check on Z.
edit: countA = countA % 1440; should be inside the interrupt routine if there is a danger of countA rolling over (ie if the dial is spinning and the main loop is slow )
// External Interrupts: See the attachInterrupt() function for details.
#define pinA1 1   //Roller A
#define pinA2 0   //Roller A
int oldA1=0, oldA2=0;
int countA=0;
int absdegrees=0;
  pinMode(pinA1, INPUT_PULLUP);
  pinMode(pinA2, INPUT_PULLUP);
  digitalWrite(pinA1, HIGH);
  digitalWrite(pinA2, HIGH);
  attachInterrupt(digitalPinToInterrupt(pinA1),doACount,CHANGE);
  attachInterrupt(digitalPinToInterrupt(pinA2),doACount,CHANGE);
  Serial.begin(9600); //This pipes to the serial monitor
  countA = countA % 1440;  //  for a 360ppr encoder ?
  absdegrees = countA / 4;  //
  Serial.println( "degrees   " + String(absdegrees));
  delay(1000); //
void doACount() {
  int newA1=digitalRead(pinA1);
  int newA2=digitalRead(pinA2);
   if((oldA1!=oldA2 && newA2!=oldA2)||(oldA1==oldA2 && newA1!=oldA1)) {
     countA = countA +1;
     countA = countA -1;
  oldA1=newA1;
  oldA2=newA2;
so i have spent some more hours learning some and trying some too
i think there are a couple things i am doing bad. lol
this looks to not be adding up "timing" properly or at all
it is running on now saying
fire 1
 fire 5
 fire 3
 fire 6
 fire 2
 fire 4
0 count
i would like to have it say
1
2
3
4
x
x
99
fire 1
101
102
x
x
218
219
fire 5
221
222
x
x
x
fire 3
fire 6
fire 2
fire 4
and so on as i run the encoder by hand
const byte EncoderDIPin = 2;       // encoder input
const byte IndexDIPin   = 3;       // index input
int COP1 = 4;                      // Digital Output Pins for turning on the COPs
int COP2 = 5;
int COP3 = 6;
int COP4 = 7;
int COP5 = 8;
int COP6 = 9;
int timing = 0;
unsigned long previousMillis = 0;
unsigned long COPdwell = 2;
    Serial.begin(9600);                         // bunch of pins
   pinMode(COP1,         OUTPUT);
   pinMode(COP2,         OUTPUT);
   pinMode(COP3,         OUTPUT);
   pinMode(COP4,         OUTPUT);
   pinMode(COP5,         OUTPUT);
   pinMode(COP6,         OUTPUT);
   digitalWrite(COP1,LOW);                        // Make sure that the injectors are initially turned off
   digitalWrite(COP2,LOW);
   digitalWrite(COP3,LOW);
   digitalWrite(COP4,LOW);
   digitalWrite(COP5,LOW);
   digitalWrite(COP6,LOW);
   while (digitalRead(IndexDIPin)==LOW) {}            // Wait for the index pulse to go high before starting the loop
                   ////////////////////////////////////////////////////////////  encoder and index input
  if (indexState != oldIndexState)            // If the 'index' signal has just gone active (LOW) reset the timer counter
    if (indexState) timing = 0;
  if (encoderState != oldEncoderState)         // If the encoder signal has just gone active (LOW) increment the timer counter
    if (encoderState) timing++;
                       /////////////////////////////////////////////////////////////    COP sequence
   unsigned long currentMillis1 = millis();
   if (timing>=100)
    digitalWrite(COP1,HIGH);
    if (currentMillis1 - previousMillis >= COPdwell) {
        previousMillis = currentMillis1;
    while (COP1,LOW); {}
    Serial.println(" fire 1");
    unsigned long currentMillis5 = millis();
   if (timing>=220)
    digitalWrite(COP5,HIGH);
    if (currentMillis5 - previousMillis >= COPdwell) {
        previousMillis = currentMillis5;
    while (COP5,LOW); {}
    Serial.println(" fire 5");
   unsigned long currentMillis3 = millis();
   if (timing>=340)
    digitalWrite(COP3,HIGH);
    if (currentMillis3 - previousMillis >= COPdwell) {
        previousMillis = currentMillis3;
    while (COP3,LOW); {}
    Serial.println(" fire 3");
   unsigned long currentMillis6 = millis();
   if (timing>=460)
    digitalWrite(COP6,HIGH);
    if (currentMillis6 - previousMillis >= COPdwell) {
        previousMillis = currentMillis6;
    while (COP6,LOW); {}
    Serial.println(" fire 6");
   unsigned long currentMillis2 = millis();
   if (timing>=580)
    digitalWrite(COP2,HIGH);
    if (currentMillis2 - previousMillis >= COPdwell) {
        previousMillis = currentMillis2;
    while (COP2,LOW); {}
    Serial.println(" fire 2");
   unsigned long currentMillis4 = millis();
   if (timing>=700)
    digitalWrite(COP4,HIGH);
    if (currentMillis4 - previousMillis >= COPdwell) {
        previousMillis = currentMillis4;
    while (COP4,LOW); {}
    Serial.println(" fire 4");
  Serial.println(" count");
  Serial.println();                                 // space in between lines for easy reading
