Pololu A-Star328PB
Have just discovered this neat board - alleged to be a drop-in replacement for most common Arduino boards. I've just run out f pins on a Nano based project, and the extra pins the (plus speed) offered by the 328PB would be a life saver. However...
After installing all the code and libraries and adding the 328 'additional path' in the IDE - cannot seem to connect to it! The same code used for the Nano compiles - but when I try and upload arvdude cannot accesst the port. After a long hang I get this error:
Uploading 'CICStepper' to 'Pololu A-Star 328PB' using 'COM5'
The uploader returned an error
Has anyone successfully load and ran a script from this board?
Please post a link to the datasheet for the A-Star board.
...R
The A-Star works great, but you have to download and select the correct Pololu board in the Arduino IDE.
Carefully read and follow the instructions on the Pololu product page.
Please do this:
  • File > Preferences > Show verbose output during: > compilation (uncheck) > upload (check) > OK
  • Sketch > Upload
  • After the upload fails you'll see a button on the right side of the orange bar "Copy error messages". Click that button.
  • Paste the error messages in a reply here USING CODE TAGS (</> button on the toolbar).
