Pololu A4988 with Arduino Uno R3 works, but not with Leonardo!
i have a Problem with the following sketch:
void Pololu_A4988_Example(){
digitalWrite(11, HIGH); // Motor On
delay(500); // delay for Controller startup
digitalWrite(9, LOW); // Turn right
for(double i = 0; i < 100000; i++) { //100000 steps in one direction
digitalWrite(10, HIGH);
delay(1);
digitalWrite(10, LOW);
delay(1);
digitalWrite(11, LOW); // Motor Off
delay(5000);
digitalWrite(9, HIGH); // Turn left
delay(1);
delay(1);
delay(5000);
it works perfect with Arduino Uno R3, but not with Arduino Leonardo!
Can someone help me? What's the problem?
kricom
I'm not sure what your problem is, but double is not a type I'd use as a loop control like that.
Try "long" or "unsigned long"
Also, it is best if you post all your code. What you posted is not a sketch.
Please use code tags when posting code
the type is not the problem!
here is all the code:
  pinMode(9, OUTPUT);       // Motor Dir
  pinMode(10, OUTPUT);     // Motor Step
  pinMode(11, OUTPUT);     // Motor On - Off
  digitalWrite(11, LOW);     // Motor Off = LOW
  Pololu_A4988_Example();
    delay(1);
    delay(1);
  delay(5000);
    delay(1);
    delay(1);
  delay(5000);
It isn't the problem...yet.
Now what does the code do that it shouldn't and what doesn't it do that it should?
