I bought the Pololu QTRX-HD-05RC 5-channel IR sensor and connected it to an Arduino Mega on pins 26-30.
I'd like to skip the calibration phase and use raw sensor values.
Using the examples based on readLineBlack(sensorValues[i]) which includes calibration, I get very good results between 0 and 1000.
However, using the non-calibrated read(sensorValues[i]), I only get values between about 150 and 650 while this should be between 0 and 2500. The difference while on or off the black line is not enough to base steering decisions on. Same IR sensors, same hardware, same black line on a white surface.
The code is entirely based on the examples from the QTR library (QTRRCExample and QTRRCRawValuesExample) included in v4.0.
I think I found the solution in the meantime. What I didn't know is that each IR sensor is not the same, so low and high return values are different for each one. Even when blocking all light I didn't get values over 650 so thought I had a problem in my code. Instead, you need to process each sensor individually to figure out whether it's on a white or black surface. It's the difference between high and low that matters, not the actual value.
If anyone with the same problem stumbles on this post, here's an easy way to solve it (at least that's how I did it). Feel free to comment if there are other, better ways to do this. Thresholds should of course be modified for your specific situation. This code will return --X-- if your sensor array is positioned correctly and something else if it's not.
#include <QTRSensors.h>
QTRSensors qtr;
const uint8_t SensorCount = 5;
uint16_t sensorValues[SensorCount];
int sensorThreshold[5] = {350,200,200,200,350};
qtr.setTypeRC();
qtr.setSensorPins((const uint8_t[]){26, 27, 28, 29, 30}, SensorCount);
qtr.read(sensorValues);
for (uint8_t i = 0; i < SensorCount; i++)
Serial.print(sensorValues[i]);
Serial.print('\t');
Serial.print('\t');
if (sensorValues[i] > sensorThreshold[i])
Serial.print("X"); // black surface detected
Serial.print("-"); // white surface detected
delay(250);
