Pololu magnetic encoder
Hello.
I'm facing some difficulties to find how to program the pololu magnetic wheel encoder
Is there any example that I can refer to? Any libraries?
Did I miss something on the Pololu site?
Cheers
Damien
Those are just basic quadrature encoders. Pretty much any quadrature encoder code should work. Here's one example.
The schematic shows the module has on-board pull-up resistors so you don't even
need pull-ups. Just connect A and B to pins 2 and 3 if you want interrupt-driven
quadrature decoding.
You will find lots of examples of code out there for this, try to find one that uses
CHANGE interrupts on both pins - its impossible to correctly account encoder steps during
direction changes without taking note of every transition. If you are only interested
in speed feedback any code is likely to be adequate.
