PololuLedStrip-add Bluetooth
Hey guys, I've been trying to add Bluetooth connectivity to this example sketch but have been unsuccessful. I have a HC-06 BT device ready to connect to my nano. I'm using WS2811 LEDs and just wish to turn them on and off over BT.
If any one can help i would appreciate it.
Thanks
Here is the code I'm running:
/* LedStripRainbow: Example Arduino sketch that shows
  • how to make a moving rainbow pattern on an
  • Addressable RGB LED Strip from Pololu.
  • To use this, you will need to plug an Addressable RGB LED
  • strip from Pololu into pin 12. After uploading the sketch,
  • you should see a moving rainbow.
#include <PololuLedStrip.h>
// Create an ledStrip object and specify the pin it will use.
PololuLedStrip<6> ledStrip;
// Create a buffer for holding the colors (3 bytes per color).
#define LED_COUNT 30
rgb_color colors[LED_COUNT];
// Converts a color from HSV to RGB.
// h is hue, as a number between 0 and 360.
// s is the saturation, as a number between 0 and 255.
// v is the value, as a number between 0 and 255.
rgb_color hsvToRgb(uint16_t h, uint8_t s, uint8_t v)
uint8_t f = (h % 60) * 255 / 60;
uint8_t p = (255 - s) * (uint16_t)v / 255;
uint8_t q = (255 - f * (uint16_t)s / 255) * (uint16_t)v / 255;
uint8_t t = (255 - (255 - f) * (uint16_t)s / 255) * (uint16_t)v / 255;
uint8_t r = 0, g = 0, b = 0;
switch((h / 60) % 6){
case 0: r = v; g = t; b = p; break;
case 1: r = q; g = v; b = p; break;
case 2: r = p; g = v; b = t; break;
case 3: r = p; g = q; b = v; break;
case 4: r = t; g = p; b = v; break;
case 5: r = v; g = p; b = q; break;
return rgb_color(r, g, b);
// Update the colors.
uint16_t time = millis() >> 2;
for(uint16_t i = 0; i < LED_COUNT; i++)
byte x = (time >> 2) - (i << 3);
colors = hsvToRgb((uint32_t)x * 359 / 256, 255, 255);
// Write the colors to the LED strip.
ledStrip.write(colors, LED_COUNT);
delay(70);
Cross-posting is against forum rules.
https://forum.arduino.cc/index.php?topic=493728.0
Also read the part about how to properly post code.
You can still add code tags to your original post.
Leo..
