I’m new bee in Arduino, I need Help To Convert ATtiny2331 Firmware to ATMEGA328 using Arduino IDE.
Please find attached files for the reference. Please help me to covert, Thanks in advance.
Sushant Chonkar.
ioport.h (827 Bytes)
main.c (2.21 KB)
Robin2
November 24, 2016, 2:44pm
#2
For short programs like that please include them in your Post so we don’t have to download them. I will do it for you this time.
main.c
#include <avr/io.h>
#include <util/delay.h>
#include <avr/interrupt.h>
#include "ioport.h"
//init timer 1 for fg sensor
void timer_init(){
ACSR = (1<<ACIC); //Analog comparator for input capture
TCCR1B = (1<<ICNC1) | 1; //noise canceler, clk/1
TIMSK |= (1<<ICIE1) | (1<<OCIE1A);
#define SET_PWM(v) OCR0A=(v)
uint8_t overflow;
volatile uint8_t freq_correct;
volatile uint8_t enabled;
ISR(TIMER1_COMPA_vect){
PORTD ^= 1<<PD1;
if(enabled){
SET_PWM(255);
overflow = 1;
OCR1A += 32768;
int16_t integral;
ISR(TIMER1_CAPT_vect){
static uint16_t old_icr;
uint16_t icr;
uint16_t y;
int16_t a;
icr = ICR1;
y = icr - old_icr;
if(y < 1000) return;
old_icr = icr;
PORTD ^= 1<<PD0;
freq_correct = 0;
OCR1A = icr + 32768; //for overflow
if(overflow == 1){
overflow = 0;
}else{
if(y < 0) y = 10000;
if(y > 10000) y = 10000;
a = y - 8000;
if((a < 40) && (a > -40)){
freq_correct = 1;
integral += a;
#define I 32
if(integral > (I*256)) integral = I*256 ;
if(integral < -(I*256)) integral = -(I*256);
a *= 1;
a += integral/I;
if(a > 255) a = 255;
if(a < 0 ) a = 0;
if(enabled){
SET_PWM(a);
#define ENABLE_PORT D
#define ENABLE_BIT 3
#define OC0A_PORT B
#define OC0A_BIT 2
#define LOCKED_PORT D
#define LOCKED_BIT 6
//init timer 0 for Motor PWM
void pwm_init(){
TCCR0A = (1<<COM0A1) | (1<<COM0A0) | (1<<WGM01) | (1<<WGM00) ; //fast inverted PWM on OC0A
TCCR0B = 1; //clk/1
OCR0A = 0;
SET_DDR(OC0A);
int main(){
pwm_init();
timer_init();
OUTPUT_ON(ENABLE);//pullup
SET_DDR(LOCKED);
DDRD |= 3;
PORTB = 3;
sei();
uint8_t locked;
uint16_t correct;
while(1){
_delay_us (100);
if(freq_correct){
correct ++;
if(correct > 2000){
correct = 2000;
locked = 1;
}else{
correct = 0;
locked = 0;
if(!INPUT(ENABLE)){
enabled = 1;
if(locked){
OUTPUT_ON(LOCKED);
}else{
OUTPUT_OFF(LOCKED);
}else{
enabled = 0;
SET_PWM(0);
OUTPUT_OFF(LOCKED);
correct = 0;
ioport.h
// Makros for simplified single pin io access.
#define PORT_(port) PORT ## port
#define DDR_(port) DDR ## port
#define PIN_(port) PIN ## port
#define PORT(port) PORT_(port)
#define DDR(port) DDR_(port)
#define PIN(port) PIN_(port)
#define SET_DDR(p) DDR(p##_PORT) |= (1<<p##_BIT)
#define CLEAR_DDR(p) DDR(p##_PORT) &= ~(1<<p##_BIT)
#define OUTPUT_ON(p) PORT(p##_PORT) |= (1<<p##_BIT)
#define OUTPUT_OFF(p) PORT(p##_PORT) &= ~(1<<p##_BIT)
#define INPUT(p) ((PIN(p##_PORT) & (1<<p##_BIT)) != 0)
Use Like this:
#define LED_PORT C
#define LED_BIT 7
#define SWITCH_PORT B
#define SWITCH_BIT 0
int main(){
SET_DDR(LED); //set to output
OUTPUT_ON(SWITCH); //turn on pullup
if(INPUT(SWITCH)){
OUTPUT_ON(LED);
}else{
OUTPUT_OFF(LED);
…R
Robin2
November 24, 2016, 2:47pm
#3
I think if that was my problem I would create an empty setup() function and change the name of your main() function to void loop() and then try to compile it with the Arduino IDE so I could see what error messages it throws up. Then work on eliminating the errors starting with the first one the compiler detects.
Also, I think I would initially compile it on the Arduino IDE for the Attiny2331 and only convert to the 328 when I had the bugs out.
...R
