polymorphism
hi, i'm experimenting with polymorphism in arduino, but I'm getting the following error message:
bi_grafic.cpp.o: In function gr_routine': C:\Users\JUANCA~1\AppData\Local\Temp\build4041774866979188726.tmp/bi_grafic.cpp:116: undefined reference tovtable for gr_routine' C:\Users\JUANCA~1\AppData\Local\Temp\build4041774866979188726.tmp/bi_grafic.cpp:116: undefined reference to `vtable for gr_routine'
does anybody know why :drooling_face:
thanks in advance
bi_grafic.h
class gr_routine {
  public:
  gr_routine();
  gr_routine(  uint8_t* driver_in  );
  virtual void execute();
protected:
  uint8_t* gr_driver;
class routine_a : public gr_routine {
public:
  routine_a(  uint8_t* driver_in  ) ;
private:
  int  a_counter1;
  int  a_counter2;
  int  a_counter3;
  uint8_t* gr_driver;
bi_grafic.cpp
gr_routine::gr_routine(  uint8_t* driver_in  )  {
  gr_driver = driver_in;
gr_routine::gr_routine(    ) {
  Serial.println("gr_routine_called");
routine_a::routine_a(  uint8_t* driver_in  ) :  gr_routine()  {
  a_counter1 = 1;
  a_counter2 = 2;
  a_counter3 = 3;
void routine_a::execute(){
  if (a_counter1 > 7) {     a_counter1 = 0;   }
  if (a_counter2 > 7) {     a_counter2 = 0;   }
  if (a_counter3 > 7) {     a_counter3 = 0;   }
/* here comes some more code */
    a_counter1++;
    a_counter2++;
    a_counter3++;
Where is this class defined?
You don't appear to have an classes that derive from gr_routine, so why is execute a virtual function? The vtable message says that you don't have any definition anywhere for this virtual function to be looked up.
thanks, I added the following code and now it started to work.
I will have a number of routines which share some data but have different "execute" functions (in the future) ;)
void gr_routine::execute(    ) {
  return;
