Pong game on 128*32 OLED display, please help!
So I decided to make a pong game from here Implementing Pong with Arduino Nano and I2C OLED 128x64 | by benjamin woehrl | Medium and I'm having a little trouble with my project.
I'm pretty sure I've wired everything correctly, and the game runs as it's supposed to, except I can't get the paddle on Player 1's side to work i.e. Player 2 stops even when player 1's paddle is blocking the ball. I adapted the code in the article for a 128*32 OLED display, so the code I'm using is below. Could someone please help me troubleshoot this?
 * Pong on Arduino UNO and 128*32 display
 * Adapted from https://medium.com/@ruction/arduino-pong-i2c-oled-128x64-bd4185970b50
#include <Wire.h>                  // This library allows you to communicate with I2C
#include <Adafruit_GFX.h>          // Adafruit GFX graphics core library
#include <Adafruit_SSD1306.h>      // Driver library for 'monochrome' 128x64 and 128x32 OLEDs
// Define the PINS you're goint to use on your Arduino Nano
int controller1 = 2;               // ANALOG 2
int controller2 = 3;               // ANALOG 3
int ledPin = 4;                    // DIGITAL 4
int btnPin = 5;                    // DIGITAL 5
// Define variables
int buttonState = 0;               // HIGH = Pressed
int gameState = 0;                 // 0 = Home, 1 = Game, 2 = End
int controllerValue1 = 0;          // variable to store the value coming from the potentiometer
int controllerValue2 = 0;          // variable to store the value coming from the potentiometer
int paddlePositionPlayer1 = 0;
int paddlePositionPlayer2 = 0;
int scorePlayer1 = 0;
int scorePlayer2 = 0;
int ballX = 128/2;
int ballY = 32/2;
int ballSpeedX = 4;
int ballSpeedY = 2;
#define OLED_RESET 4
Adafruit_SSD1306 display(OLED_RESET);
#if (SSD1306_LCDHEIGHT != 32)
  #error("Height incorrect, please fix Adafruit_SSD1306.h!");
#endif
  pinMode(ledPin, OUTPUT);
  pinMode(btnPin, INPUT);
  display.begin(SSD1306_SWITCHCAPVCC, 0x3C);  // initialize with the I2C addr 0x3C (for the 128x64)
  display.clearDisplay();
  digitalWrite(ledPin, HIGH);                 // Status led on...
  // Read controller value and calculate paddle position
  controllerValue1 = analogRead(controller1);
  controllerValue2 = analogRead(controller2);
  paddlePositionPlayer1 = controllerValue1 * (46.0 / 1023.0);
  paddlePositionPlayer2 = controllerValue2 * (46.0 / 1023.0);
  // Set button state
  buttonState = digitalRead(btnPin);
  if (buttonState == HIGH && gameState == 0) {
      gameState = 1;
      delay(100);
  } else if (buttonState == HIGH && (gameState == 1 || gameState == 2)) {
      gameState = 0;
      scorePlayer1 = 0;
      scorePlayer2 = 0;
      ballX = 128/2;
      ballY = 32/2;
      delay(100);
  if (gameState == 0) {
    display.setTextSize(2);
    display.setTextColor(WHITE);
    display.setCursor(37, 6);
    display.println("PONG");
    display.setTextSize(1);
    display.setCursor(27, 20);
    display.println("press start");
    display.display();
  if (gameState == 1) {
    drawField(scorePlayer1, scorePlayer2);
    collisionControl();
    drawBall();
    display.display();
  if (gameState == 2) {
    if (scorePlayer1 == 2) {
      display.setCursor(7, 15);
    } else if (scorePlayer2 == 2) {
      display.setCursor(38, 15);
    display.println("winner!");
    display.display();
void drawField(int score1, int score2) {
    display.fillRect(0, round(paddlePositionPlayer1), 2, 9, 1);
    display.fillRect(126, round(paddlePositionPlayer2), 2, 9, 1);
    display.setCursor(55, 0);
    display.print(score1);
    display.print(":");
    display.print(score2);
    display.fillRect(63, 12, 1, 5, 1);
    display.fillRect(63, 22, 1, 5, 1);
    display.fillRect(63, 32, 1, 5, 1);
    display.fillRect(63, 42, 1, 5, 1);
    display.fillRect(63, 52, 1, 5, 1);
    display.fillRect(63, 62, 1, 5, 1);
void collisionControl() {
  //bounce from top and bottom
  if (ballY >= 32 - 2 || ballY <= 0) {
    ballSpeedY *= -1;
  //score points if ball hits wall behind player
  if (ballX >= 128 - 2 || ballX <= 0) {
    if (ballSpeedX > 0) {
      scorePlayer1++;
      ballX = 128 / 4;
    if (ballSpeedX < 0) {
      scorePlayer2++;
      ballX = 128 / 4 * 3;
    if (scorePlayer1 == 4 || scorePlayer2 == 4) {     //set the score to win
      gameState = 2;
  //bounce from player1
  if (ballX >= 0 && ballX <= 2 && ballSpeedX < 0) {
    if (ballY > round(paddlePositionPlayer1) - 2 && ballY < round(paddlePositionPlayer1) + 9) {
      ballSpeedX *= -1;
  //bounce from player2
  if (ballX >= 128-2-2 && ballX <= 128-2 && ballSpeedX > 0) {
    if (ballY > round(paddlePositionPlayer2) - 2 && ballY < round(paddlePositionPlayer2) + 9) {
      ballSpeedX *= -1;
void drawBall() {
  display.fillRect(ballX, ballY, 2, 2, 1);
  ballX += ballSpeedX;
  ballY += ballSpeedY;
Either the comment is wrong, or the pin number is wrong. Analog pin 2 is A2.
wvmarle:
It's no difference for analogRead, which is the only usage of those variables.
Using A2 and A3 you would not need a comment.
Whandall:
Yet another horrible design decision in the Arduino IDE... It's just unbelievable that they made it so that analogRead(A2) reads data from the same pin as analogRead(2) and analogRead(16). Especially as there's a physical pin 2 on the board, and another that's called A2.
Yet digitalRead(2) and digitalRead(A2) actually do read from a different pin... where digitalRead(A2) is the same as digitalRead(16).
That's just asking for confusion and mistakes!
