Pool Salt Water Chlorine Generator
Here's part 2 -
// Setup Routine Information
void setup()                    // run once, when the sketch starts
 Serial.begin(9600); // start up serial communications
  pinMode(FlowPin, INPUT);     // sets the digital pin as input
  pinMode(UpButtonPin, INPUT);
  pinMode(DnButtonPin, INPUT);
  pinMode(K1Pin, OUTPUT);      // sets the digital pin as output
  pinMode(K2Pin, OUTPUT);      // sets the digital pin as output
  pinMode(K3Pin, OUTPUT);      // sets the digital pin as output
  pinMode(FanPin, OUTPUT);      // sets the digital pin as output
  pinMode(RpwrPin, OUTPUT);
  pinMode(LpwrPin, OUTPUT);
  for (int i = 0; i < 8; i++)
    pinMode(ledPin[i], OUTPUT);      // sets the digital pin as output
  digitalWrite(UpButtonPin, HIGH);  //Turn on the pull up resistors
  digitalWrite(DnButtonPin, HIGH);  //Turn on the pull up resistors
  digitalWrite(FlowPin, HIGH);  //Turn on the pull up resistors
  display_time();                  // Show initial time
  Mode0();                            //Set relays OFF
  // Get ct from the EEPROM
  ctRead = EEPROM.read(0);
  delay(100);
  Rcount = ctRead; //**ERROR** MUST comment out the first time if a value has not ever been stored before!!!!
  MsTimer2::set(1000, increment_time);// every second increment_time() is called
  MsTimer2::start();
//Main Program LOOP
void loop(){
  if (tick) {         // If a tick has occurred
      tick = 0;
        Serial.println(""); // This prints to the console for debugging
        Serial.print("Time is ");         //    reset indicator that we have a new time
      display_time();  //    and show it off!
        Serial.print("Flow Status = ");
        if (FlowState == 0) {Serial.println("GOOD FLOW");}
        if (FlowState == 1) {Serial.println("BAD FLOW");}
        Serial.print("Cell Power Mode is ");
        if (Mode == 0) {Serial.println("WAITING");}
        if (Mode == 1) {Serial.println("FORWARD"); // Make Chlorine, show Run Time remaining
          digitalWrite (RpwrPin, HIGH); //Turn ON the display
          hours=(Rcount -((minutes - (StartDelay)) / 60));  //Calculate how many Run Time Hours are left
          drawDigit(hours);  //Show remaining Run Time Hours
        if (Mode == 2) {Serial.println("REVERSE");
        if (Mode == 3) {Serial.println("DONE");
        digitalWrite (RpwrPin, LOW); //Turn Off the display
// While there is GOOD FLOW run the program
FlowState = digitalRead(FlowPin); //Check for GOOD FLOW
if (FlowState == 0){
//If minutes < delay, then check for button input to change run time
if (minutes < (StartDelay)) {
      Mode = 0;
      SetTime();
if (minutes == (StartDelay)) {CycleTime = Rcount * 60;} // Start-up delay is over, Now use Input Count for Cycle Time
if (minutes > (StartDelay) && minutes < ((CycleTime) + (StartDelay))) {
            if (Rcount != ctRead)                   //Was Count for Hours of Operation changed?
                    {EEPROM.write(0, int(Rcount));      // Then Write NEW count to the EEPROM
                     delay(20);}
                MoRead = EEPROM.read(1);                //Read what Cell Power Mode to use
                if (MoRead == 1) {Mode1();
                else {Mode2();
   }            //Generate Chlorine in Last Saved Mode for this cycle
if (minutes > ((CycleTime) + (StartDelay))) {
        Mode0();
        Mode = 3;    //Cycle completed, go back to waiting
        CyRead = EEPROM.read(2);    //Read how many cycles have been run before
         CyRead ++;                    //And add 1 to it
         if (CyRead >= Cycles)    //Next Time self clean
          {if (MoRead ==2)
          {MoRead = 1;}
        else {MoRead = 2;}
    EEPROM.write(1, int(MoRead));    //Write the Mode to use next time to memory
    EEPROM.write(2, 0);    //Set the cycles run since self cleaning to 0
      else {EEPROM.write(2, (CyRead));}  // Write the updated cycle count to memory
else {
Mode0();
Mode = 0;                         //BAD FLOW sit Idle WAITING
digitalWrite (RpwrPin, LOW);     // And Turn Off the LED display
// Cell Relay Power Control Functions to Generate Chlorine
 void Mode0() {                     // CELL is IDLED - No Power
  digitalWrite(K1Pin, HIGH);        // Connects +5V & +24V power to K2 & K3
  digitalWrite(K2Pin, LOW);         // CELL IDLE - Connects Cell (+) to +24V
  digitalWrite(K3Pin, LOW);         // CELL IDLE - Connects Cell (-) to +24V
  //when done turn the fan off
  digitalWrite(FanPin, LOW);        // sets the FAN off, after cooling the rectif
//______________________________________________________________
//         CHLORINE GENERATION POWER MODES
void Mode1() {                     // FORWARD power to cell
  Mode = 1;                        // Apply Positve polarity power to cell
 digitalWrite(K3Pin, HIGH);        // NORMAL POLARITY - Connects Cell (-) to GROUND
 //Turn the fan ON to keep things cool
  digitalWrite(FanPin, HIGH);       // sets the FAN on to cool the rectifier
 void Mode2() {                    //REVERSE polarity for SELF CLEANING
  Mode = 2;                        //Apply REVERSE Polarity power to cell
  digitalWrite(K2Pin, HIGH);        // REVERSE POLARITY - Connects Cell (+) to GROUND
I hope that you find this useful!
I welcome any comments/suggestions on how to improve this project, what I am after is a low cost, easy to use, effective Electronic Chlorine Generation system for use in residential pools.
