Poor coding structure--need help
Before arduino, I've never used C. My prior experience, which is mainly fortran, pascal, basic, and assembly, is from classes in school and not really for real life interfacing, etc. My delimma is this: I believe I need a state machine structure. I think I'm on the right track, but I need an experienced coding jedi to steer me in the right direction. Attached is my program. I'm trying to enter values in the first two menus and then show the total value in the last menu. I think I'm close, but my program gets stuck somewhere. Any help would be greatly appreciated.
#include <LiquidCrystal.h>
//This is a short program to explore a method of using delay timing to
//cause a value to incriment slowly until the button has been held down
//for a period of time, after which it will incriment much faster
//The initial delay is reset if the button is released
//LiquidCrystal(rs, rw, enable, d0, d1, d2, d3)
//My Display pinout(rs-4, rw-5, enable-6, d0-11, d1-12, d2-13, d3-14)
LiquidCrystal lcd(12, 11, 10, 5, 4, 3, 2);
int backBtn = 14; //These are the input buttons
int incBtn = 15;
int decBtn = 17;
int nextBtn = 18;
int selectBtn = 16;
int milliSeconds = 0; //starting value for milliSeconds
int microSeconds = 0;
int del = 10; //This is my delay while the button is pressed
int back; //The values used for a digital read
int inc;
int dec;
int next;
int select;
int debounce = 20; //button debounce time
int state = 0;
pinMode(backBtn,INPUT); //set pin as input
digitalWrite(backBtn, HIGH); //turn on the internal pull-up
pinMode(incBtn,INPUT);
digitalWrite(incBtn, HIGH); //turn on the internal pull-up
pinMode(selectBtn,INPUT);
digitalWrite(selectBtn, HIGH); //turn on the internal pull-up
pinMode(decBtn,INPUT);
digitalWrite(decBtn, HIGH); //turn on the internal pull-up
pinMode(nextBtn,INPUT);
digitalWrite(nextBtn, HIGH); //turn on the internal pull-up
constrain(del, 0, 10); //limit the range of values for del
constrain(milliSeconds, 0, 999); //limit the range of values for milliSeconds
constrain(microSeconds, 0, 999);
constrain(state, 0, 2);
// lcd.clear();
// lcd.print("Hi-Speed Camera");
// lcd.setCursor(0,1);
// lcd.print(" delay timer");
// delay(3000);
// lcd.clear();
currentState(); //go to the first menu -- choose the milliseconds value
if(state == 0)
choosemilliSeconds();
if(state == 1)
choosemicroSeconds();
if(state == 2)
showTotalTime();
} //close void loop
void btnPressed()
if (del > 0) //if del value is greater than 0, we want
{ // to delay a bit to increment more slowly
del=(del-1);
delay(250);
} //close void btnPressed
void printRightArrow()
lcd.setCursor(11,1);
lcd.print("next");
lcd.write(0b01111110);
void printLeftArrow()
lcd.setCursor(0,1);
lcd.write(0b01111111);
lcd.print("back");
void printmilliSeconds()
lcd.setCursor(0,0);
if (milliSeconds < 100)
lcd.print("0"); //add zeroes as place holders on the display
if (milliSeconds <10)
lcd.print("0");
lcd.print(milliSeconds); //print the current value on the display
lcd.print(" msec");
void choosemilliSeconds()
readBtns();
while(next == HIGH)
readBtns();
printmilliSeconds();
printRightArrow();
if (dec == LOW) //If I press the decriment button, begin reducing the milliSeconds value
if(milliSeconds >0)
milliSeconds = (milliSeconds-1);
btnPressed();
if (inc == LOW) //If I press the incriment button, begin increasing the milliSeconds value
if(milliSeconds <999)
milliSeconds = (milliSeconds+1);
btnPressed();
readBtns();
/* if(next == LOW)
}*/ //close While loop
} //close void choosemilliSeconds
void readBtns()
back = digitalRead(backBtn); //Read the value of backBtn
next = digitalRead(nextBtn); //Read the value of nextBtn
select = digitalRead(selectBtn); //Read the value of selectBtn
inc = digitalRead(incBtn); //Read the value of incBtn
dec = digitalRead(decBtn); //Read the value of decBtn
delay(debounce); //Wait a short time
if (back == HIGH && next == HIGH && inc == HIGH && dec == HIGH && select == HIGH)
del = 10; //if no buttons are pressed, del is set to 10
void choosemicroSeconds()
readBtns();
while(back == HIGH && next == HIGH)
readBtns();
printmicroSeconds();
printLeftArrow();
printRightArrow();
if(microSeconds >0)
microSeconds = (microSeconds-1);
btnPressed();
if(microSeconds <999)
microSeconds = (microSeconds+1);
btnPressed();
} //close While loop
/* readBtns();
if(next == LOW)
// lcd.clear();
showTotalTime();
if(back == LOW)
[color=#7
...Any help would be greatly appreciated.
It would've been simpler if you posted the whole code. If it is long you maybe want to use http://arduino.pastebin.com/
Post here again when that is done, including a URL if you decide to use pastebin. I'll gladly do my best to help.
:slight_smile:
I think I have this thing figured out. I think my debounce time was too short. I increased the time and I seem to have all of the menus that I expected to have. I'll play with it some more and let you know how it goes. Thanks for your help.
Looks like you've misunderstood the use of 'constrain' as a library function. You can't call it in your 'setup()' code and expect it to constrain the variable throughout your code (nice though that would be). You must call 'constrain()' each time you want the variable's value to be constrained, and you must assign the result back into a variable (i.e. 'constrain()' is a function returning a value).
Could you post the whole of your sketch code?
Here is what I have at this time. I'm trying to get these 3 menus to work. There is some code that has been commented out. That was some stuff that I was trying, but had even less success with. Once I get the menus working, I'll move on, so here's what I have so far:
int incBtn = 15;
int decBtn = 17;
int nextBtn = 18;
int selectBtn = 16;
int inc;
int dec;
int next;
int select;
int state = 0;
//    lcd.clear();
//    delay(3000);
//    lcd.clear();
        if(state == 0)
    if(state == 1)
    if(state == 2)
        showTotalTime();
  }                               //close void loop
void btnPressed()
        del=(del-1);
        delay(250);
    lcd.print("next");
    lcd.setCursor(0,1);
    lcd.print("back");
    lcd.setCursor(0,0);
        lcd.print("0");
      lcd.print(" msec");
    readBtns();
    while(next == HIGH)
    readBtns();
    printRightArrow();
      if(milliSeconds >0)
      btnPressed();
      btnPressed();
  readBtns();
/*  if(next == LOW)
void readBtns()
    readBtns();
     readBtns();
    printLeftArrow();
    printRightArrow();
      if(microSeconds >0)
      btnPressed();
      btnPressed();
/*     readBtns();
  if(next == LOW)
//   lcd.clear();
   showTotalTime();
  if(back == LOW)
//    lcd.clear();
  }                          //close void choosemicroSeconds
void printmicroSeconds()
    lcd.setCursor(0,0);
    if (microSeconds < 100)
    if (microSeconds <10)
        lcd.print("0");
      lcd.print(microSeconds);  //print the current value on the display
      lcd.print(" usec");
   }                            //close void printmicroSeconds
void showTotalTime()          //show the total delay time
    readBtns();
     readBtns();
    printLeftArrow();
    printRightArrow();
    lcd.setCursor(0,0);
   lcd.print("0.");
        lcd.print("0");
   lcd.print(",");
        lcd.print("0");
      lcd.print(" sec");
/*     readBtns();
  if(next == LOW)
   lcd.clear();
  if(back == LOW)
    lcd.clear();
 }                              //close showTotalTime
void currentState()
    readBtns();
    delay(debounce);
    if(back == LOW)
        state = state-1;
    if(next == LOW)
        state = state-1;
//        return;
I think maybe you should start over.
Open a new sketch and implement some functionality, get it to work, and implement the next.
I often find it useful to separate the operations needed, such as:
//LOOP
//READ BUTTON STATES
//DO LOGIC THAT USES BUTTON STATES
//DO OTHER LOGIC
//OUTPUT THE RESULTS
I've actually made two libraries becuase of you code :slight_smile: Thank you for the inspiration.
The two libs are:
  • Menu Library
  • Makes creating and managing menu systems easier.
  • Event based, no source code needs to be edited.
  • Constrain Library
  • Creates variables that are constrained throughout the scope of that variable. No longer needed to call constrain() everytime you need to use the variable.
PostScriptum: Although it might seem wierd to post my libraries like this, I do not intend for anything but to be helpful for others.
That's kind of what I'm getting from one of our software engineers at work. She has suggested using routines that test states and change variables. Once the variable is processed, change it back to its original state, for example. I'll get back to you.
