Poor localization
I did some tests with a MKRFOX1200 in Belgium (Antwerp). In a first test I did a tour with my bycicle. In a second test I drove by car between Antwerp and Hasselt. You can find the results of the tests here. The localization is useless if you want to use it to track a device. Is this due to the Sigfox technologie, the coverage in Belgium, the testplatform (MKRFOX1200) or any other reason? And will this improve?
My code:
SigFox send message.
#include <SigFox.h>
#include <ArduinoLowPower.h>
unsigned long timeBetweenMessages = 10 * 60 * 1000; //wait x (first number) minutes
bool debugViaLedFull = false;
bool debugViaLedSend = true;//false;//
bool debugViaLedSetup = true;
bool sigfoxDebug = true;//false;//
int messageCounter = 0;
// On MKRFOX1200 the onboard LED is connected to D6
pinMode(6, OUTPUT);
// Reset Sigfox module
SigFox.reset();
// Start the module
if (!SigFox.begin()) {
// Something is really wrong, try rebooting
// Reboot is useful if we are powering the board using an unreliable power source
// (eg. solar panels or other energy harvesting methods)
reboot();
// Wait at least 30mS after first configuration (100mS before)
delay(100);
if (sigfoxDebug) SigFox.debug();
// Shut down module, back to standby
SigFox.end();
// Blink when setup is ready
if (debugViaLedSetup) blinking(100,2);
/* Main loop */
if (debugViaLedFull) blinking(3000,1);
messageCounter = messageCounter+1;
String TextToSend = “VNP” + SigFox.ID() + String(messageCounter);
sigfoxSend(TextToSend);
if (sigfoxDebug) {
delay(timeBetweenMessages);
LowPower.sleep(timeBetweenMessages);
if (debugViaLedFull) blinking(300,7);
/* Funtion to send messages over Sigfox */
void sigfoxSend(String str) {
if (debugViaLedFull) blinking(300,2);
// Start the module
reboot();
delay(100);
// Clears all pending interrupts
SigFox.status();
delay(1);
if (debugViaLedSend or debugViaLedFull) blinking(300,3);
SigFox.beginPacket();
if (debugViaLedFull) blinking(300,4);
SigFox.print(str);
if (debugViaLedFull) blinking(300,5);
int result = SigFox.endPacket(true);
// shut down module, back to standby
SigFox.end();
/* Funtion to use the onboard LED for debug /
Parameters: - upTime: number of ms the LED is up /
- xTimes: number of blinks */
void blinking(unsigned long upTime,int xTimes) {
delay(3000);
for (int x = 0; x<xTimes; x++) {
digitalWrite(6, HIGH); // turn the LED on (HIGH is the voltage level)
delay(upTime); // wait for [upTime] ms
digitalWrite(6, LOW); // turn the LED off by making the voltage LOW
/* Reboot */
void reboot() {
NVIC_SystemReset();
while (1) ;
