I have a couple of RC cars and have 3 relatively cheap Tx/Rx combos. These combos suit my needs with the exception of the one for my on-road race car, the missing functionality is expo. On the high speed straights the steering is too sensitive and I would like to soften it.
I thought of doing an Arduino project reading out the steering channel PWM signal from the receiver and via an algorithm change it to create the expo functionality.
This is a photo of what I want to achieve, depending on the value of a potentiometer have a certain degree of expo (t (for "thickness" of expo)).
Vertical axis: PWM signal from uC to servo
Horizontal axis: PWM signal from receiver to uC
This is a photo of the electrical circuit I think I need. (I have left out the transponder)
This is the sketch so far, I have divided it into "chapters" (A, B, C & D) to help discussing it.
Sketch: "poor_mans_expo"
This sketch is to be used in an electrical circuit on the steering channel
of a model RC car to add the expo functionality when this
functionality is not present in the Tx/Rx combo
The sketch is written for use in a ATtiny45 uC.
The two reasons for this project are learning and to save the need
for a more expensive high end Tx/Rx combo.
by Leo Groeneveld
#include <Servo.h>
Servo myservo; // create servo object to control a servo
int potPin = 2; // select the input pin for the potentiometer (hardware pin 7 on ATtiny45)
int pin = 1; // select the input pin for the PWM signal from the receiver ch. 1 (hardware pin 6 on ATtiny45)
int val = 0; // variable to store the value coming from the sensor
unsigned long duration;
Put example code here during programming, remove after use.
pinMode(pin, INPUT);
myservo.attach(0); // attaches the servo on pin 0 to the servo object (hardware pin 5 on ATtiny45)
A) In this part of the sketch the pulse width of the receiver signal to the servo is read.
duration = pulseIn(pin, HIGH); // read the PWM signal from the receiver ch. 1
B) In this part of the sketch the adjustment of the potentiometer is read.
This adjustment is used to set the level of expo of the signal to the servo.
val = analogRead(potPin); // read the value from the potentiometer
C) In this part of the sketch the algorithm is located to calculate the PWM signal to the servo from
the PWM signal from the receiver and the adjustment of the potentiometer.
// The result is a value (val) between 1 and 179 that is to be sent to the servo. (This the the TROUBLE AREA)
D) In this part of the sketch the calculated value of the PWM signal is sent to the servo.
myservo.write(val); // sets the servo position according to the scaled value
delay(5); // waits for the servo to get there (I'm not sure this line is needed due to the minimum delay of 18ms in PWM signal between pulses)
// Now start again.
Now the main question:
Because I'm not able to do the math needed to write the algorithm, can you please help me with that?
Regards,
Leo
