I'm building this coffee roaster from a YouTube video from Ben Eagen and the code isn't working with my setup. My setup is exactly like his but I'm getting multiple errors can anyone help me out?
Here is the code I've put it IDE
#include "MAX31855.h"
const int doPin = 7;
const int csPin = 6;
const int clPin = 5;
const int relayPin = 13;
MAX31855 tc(clPin, csPin, doPin);
float getTemp() {
float temp = 0;
for (int i = 0; i < 3; i++) {
temp += tc.getTemperature();
delay(5);
return temp / 3;
int getSecondsSinceStart() {
return millis() / 1000;
int getHeaterOffTime(float targetTemp, int maxDelay) {
int status = tc.read();
if (status != 0) {
Serial.print("Error status in probe, disabling heater: ");
Serial.println(status);
return maxDelay;
float currentTemp = getTemp();
// Error describes how far off the target temperature are. This should scale how long heater stays on, or off.
float error = max(0, currentTemp) / targetTemp;
float scalingFactor = 2;
float heatDelay = error * error * error * (maxDelay/scalingFactor) - maxDelay*0.2;
// make sure delay says between 0 and maxDelay
heatDelay = max(0, min(maxDelay, heatDelay));
// Serial.println("Current Temp, Target Temp, Cooling Period");
Serial.print(currentTemp);
Serial.print(",");
Serial.print(targetTemp);
Serial.print(",");
Serial.print(heatDelay);
return heatDelay;
// This function allows a warm up phase, first target temp, and second target temp,
// and finally sets target temp to zero to allow the fan to cool the beans
float getTargetTemp() {
//Time to bring roaster and beans up to a casual warm temp
const int preHeatTimeSeconds = 120;
float preHeatTemp = 120;
//Time at the first roast temp
const int firstTempTimeMins = 9;
float firstRoastTemp = 150;
//Time at the second roast temp
const int secondTempTimeMins = 4;
float secondRoastTemp = 200;
int secondsSinceStart = getSecondsSinceStart();
bool startRoast = secondsSinceStart > preHeatTimeSeconds;
bool preheat = !startRoast;
bool startSecondPhase = secondsSinceStart > preHeatTimeSeconds + firstTempTimeMins * 60;
bool cooldown = secondsSinceStart > preHeatTimeSeconds + (firstTempTimeMins + secondTempTimeMins) * 60;
// Check roasting conditions in reverse order because once these bool values are true,
// they remain true even as subsequent phases start
if (cooldown) {
return 0;
} else if (startSecondPhase) {
return secondRoastTemp;
} else if (startRoast) {
return firstRoastTemp;
} else if (preheat) {
return preHeatTemp;
return 0;
Serial.print("Starting loop: ");
Serial.println(MAX31855_VERSION);
tc.begin();
pinMode(relayPin, OUTPUT);
float targetTemp = getTargetTemp();
int updateInterval = 500;
int heaterOffDelay = getHeaterOffTime(targetTemp, updateInterval);
int heaterOnDelay = updateInterval - heaterOffDelay;
// Turn on heater
digitalWrite(relayPin, HIGH);
delay(heaterOnDelay);
delay(5);
digitalWrite(relayPin, LOW);
delay(heaterOffDelay);
