Popular/Standard H-Bridges and Motor Drivers
Hey y'all I have a question which I am guessing is an FAQ. What is a popular/standard H-bridge or motor driver for a uni-polar stepper motor? I have a uni-polar stepper that has 5 leads, red for the power and the rest go into the coils (yellow, orange, brown, black) with 7.5 degrees per step (or 48 steps per revolution).
I just finished a lab experiment where we set-up a stepper motor with 4 transistors (TIP 120) darlingtons and was such a pain to wire everything. I'm looking for an h-bridge or a motor driver that can do the job of 4 transistors in one package when I hook up four digital pins to it. I use Arduino Uno if that aids anyone in knowing my situation. Thanks
Hello,
Although I am not an expert at wiring stepper motors, My understanding is that the standard way to drive unipolar steppers is to use either a ULN2003 or ULN2004 Darlington Array. (The ULN2004 is described in the stepper tutorial: http://arduino.cc/en/Tutorial/MotorKnob)
Joshua
You can use a Darlington array as suggested, or a dedicated unipolar motor driver like an SLA7026. This device has some extra features like current control, plus it's heatsinked for higher power operation.
The Gadget Shield: accelerometer, RGB LED, IR transmit/receive, light sensor, potentiometers, pushbuttons
You referring to the SLA7026?
Yes:
http://www.allegromicro.com/en/Products/Part_Numbers/97024/97024.pdf
The Quick Shield: breakout all 28 pins to quick-connect terminals
Thanks, I'll check it out
