Is there a way to alter the timing of the keyword popups in the IDE or moving the location of the popup?
It can be frustrating trying to get to some code with the cursor as the popup appears nearly instantly preventing you access to edit the keyword etc. Can the popup popup after say 2 seconds as this will allow you time to click the mouse and get the edit point.
Also when the popup happens the popup covers the keyword your trying to get to along with the surrounding code. Can the popup be positioned above the line or below which will allow you access to click the edit point.
In the attached photo, I moved the cursor to a "Serial.print" statement on line 32 and the popup appears instantly covering the whole line nearly.
