bemin
September 7, 2017, 12:22pm
1
Hi GUys,
The story begins when I was trying to compile arduino bootloader on my WINDOWS 10 machine and I kept getting error (Vrr-gcc can't START) , then I decided to compile on LINUX so I installed a Unbunt-ON a VirtualBOX on my windows 10 machine. It is working great. Then I insatlled Arduino IDE, but the issue is that the Port option under tools is grayd out ?
why, and how can I solve that? see attached image for clarification
tf68
September 7, 2017, 5:52pm
2
In a terminal, with the board plugged in, enter lsusb.
Look for:
ID 2341:nnnn an Arduino board, will show up as /dev/ttyACM?
ID 0403:6001 Future Technology Devices International, will show up as /dev/ttyUSB?
In a terminal, with the board plugged in, enter:
ls -l /dev/ttyUSB* or ls -l /dev/ttyACM*, this will show the group that has access to the port.
Example: crw-rw-r-- 1 root dialout ... /dev/ttyACM0, root is owner, dialout is the group with access.
No luck with lsusb or ls -l. Maybe the usb cable is bad, try another, maybe the board is bad.
Entering the command, groups, in a terminal will show the groups you belong to.
sudo adduser YourUserName GroupToJoin Will fix things if you need to join a group, logout and login after you run adduser.
sudo usermod -a -G GroupToJoin YourUserName will do the same.
modem-manager can also be a problem -- most people just remove the package.
bemin
September 7, 2017, 7:25pm
3
still an issue
after typing LSUSB i get :-
BUS 001 DEVICE 005: ID 2341:8037 Arduino SA
then I type : ls -l /dev/ttyACM* I get:-
/dev/ttyACM0
nothing before it , so now I don't which group it belongs to and when I try sudo i get an error
"usermod : group '/dev/ttyACM9' doesn't exist.
tf68
September 8, 2017, 4:12am
4
ls -l -l is a lowercase L NOT a ONE!
dialout is the likely group
sudo adduser YourUserName dialout
