Oh excellent, thanks I wasn’t aware of that. I’ve a lot to learn!
There’s a lot of redundant elements in this code, it’s a bit of a mess at the moment too…
#include <PriUint64.h>
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
#include <avr/io.h>
//Addresses
const uint64_t addressSetup[2] = { 0x1000000000LL, 0x100000000ALL }; //read pipe then write pipe
const uint64_t address1[2] = { 0x2000000000LL, 0x200000000ALL };
const uint64_t address2[2] = { 0x3000000000LL, 0x300000000ALL };
//Channels (2mhz apart, minimum @1mbps)
const int chanSetup = 102;
const int chan1 = 114;
const int chan2 = 106;
RF24 radio(9, 10); // CE, CSN
int radioSerialr[15] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0}; //third from last number is power LED status, last two are address/channel (01 etc)
int radioSerialw[15] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0}; //third from last number is power LED status, last two are address/channel (01 etc)
int led1=2;
int led2=3;
int led1State=LOW;
int led2State=LOW;
int a9999counter=0;
unsigned long previousMillis = 0;
const long setupBlinkPeriod = 1000;
const long initBlinkPeriod = 50;
const long pairedBlinkPeriod = 5;
bool ping=false;
int pingtimer=5000;
int up=4;
int down=6;
int left=A0;
int right=7;
int start=8;
int select=A6;
int buttona=5;
int buttonb=5;
int buttonc=8;
int buttond=A4;
bool initPair=false;
bool paired=false;
uint64_t rAddress=address1[0];
uint64_t wAddress=address1[1];
int channel=chan1;
int padSelect=A1;
int selectState=0;
void LEDcontrol() {
if (radioSerialr[0]==1 || radioSerialr[1]==1 || radioSerialr[2]==1 || radioSerialr[3]==1 || radioSerialr[4]==1 || radioSerialr[5]==1 || radioSerialr[6]==1 || radioSerialr[7]==1){
PORTD |= (1<<PORTD2);
PORTD &=~(1<<PORTD3);
}else{
PORTD &=~(1<<PORTD2);
// unsigned long currentMillis = millis();
// if (currentMillis - previousMillis >= setupBlinkPeriod){
// previousMillis = currentMillis;
// if (led1State == LOW){
// led1State = HIGH;
// led2State = LOW;
// }else{
// led1State = LOW;
// led2State = LOW;
// digitalWrite(led1, led1State);
// digitalWrite(led2, led2State);
// Initialize NRF24L01
// Serial.begin(2000000); //for testing, can be removed later
radio.begin();
radio.setChannel(channel);
radio.setDataRate(RF24_250KBPS);
radio.setPALevel(RF24_PA_HIGH);
radio.openWritingPipe(wAddress);
radio.openReadingPipe(1, rAddress);
radio.startListening();
pinMode(padSelect, INPUT);
pinMode(led1, OUTPUT);
pinMode(led2, OUTPUT);
pinMode(up, OUTPUT); //up
pinMode(down, OUTPUT); //down
pinMode(left, OUTPUT); //left
pinMode(right, OUTPUT); //right
pinMode(start, OUTPUT); //start
pinMode(select, OUTPUT); //select
pinMode(buttona, OUTPUT); //A
pinMode(buttonb, OUTPUT); //B
pinMode(buttonc, OUTPUT); //C
pinMode(buttond, OUTPUT); //D
digitalWrite(up, HIGH);
digitalWrite(down, HIGH);
digitalWrite(left, HIGH);
digitalWrite(right, HIGH);
digitalWrite(select, HIGH);
digitalWrite(start, HIGH);
digitalWrite(buttona, HIGH);
digitalWrite(buttonb, HIGH);
digitalWrite(buttonc, HIGH);
digitalWrite(buttond, HIGH);
DDRD = B11111100; //PD4-PD7 OUTPUTS
DDRC = B00000101; //PC0 OUTPUT, PC1 INPUT
// Last state of the buttons
int lastButtonState[12] = {0,0,0,0,0,0,0,0,0,0,0,0};
if (radio.available()) {
radio.read(&radioSerialr, sizeof(radioSerialr));
LEDcontrol();
// while (paired==false){
// pair();
// // Serial.println(PriUint64<HEX>(wAddress));
//Serial.println((PINC&B00000010));
//char test[15];
//sprintf(test,"%d%d%d%d%d%d%d%d%d%d%d%d%d%d%d",radioSerialr[0],radioSerialr[1],radioSerialr[2],radioSerialr[3],radioSerialr[4],radioSerialr[5],radioSerialr[6],radioSerialr[7],radioSerialr[8],radioSerialr[9],radioSerialr[10],radioSerialr[11],radioSerialr[12],radioSerialr[13],radioSerialr[14]);
//Serial.println(test);
//char test2[15];
//sprintf(test2,"%d%d%d%d%d%d%d%d%d%d%d%d%d%d%d",radioSerialw[0],radioSerialw[1],radioSerialw[2],radioSerialw[3],radioSerialw[4],radioSerialw[5],radioSerialw[6],radioSerialw[7],radioSerialw[8],radioSerialw[9],radioSerialw[10],radioSerialw[11],radioSerialw[12],radioSerialw[13],radioSerialw[14]);
//Serial.println(test2);
if ((!PINC & B00000010)){
if (radioSerialr[2] == 1) {
PORTC &=~(1<<PORTC0);
if (radioSerialr[1] == 1){
PORTD &=~(1<<PORTD6);
}else{
PORTD |= (1<<PORTD6);
if (radioSerialr[4] == 1){
PORTD &=~(1<<PORTD4);
}else{
PORTD |= (1<<PORTD4);
if (radioSerialr[5] == 1){
PORTD &=~(1<<PORTD5);
}else{
PORTD |= (1<<PORTD5);
if (radioSerialr[0] == 1){
PORTC &=~(1<<PORTC2);
}else{
PORTC |= (1<<PORTC2);
if ((PINC & B00000010)){
}else{
}else{
if (radioSerialr[2] == 1){
}else{
PORTC |= (1<<PORTC0);
if (radioSerialr[3] == 1){
PORTD &=~(1<<PORTD7);
}else{
PORTD |= (1<<PORTD7);
if (radioSerialr[6] == 1){
}else{
if (radioSerialr[7] == 1){
}else{
I’m thinking it just isn’t running fast enough, if I query the truth of the select pin every time I query the status of my buttons it behaves very erraticly. The A and Start buttons begin to work but not as the right buttons and everything is very unstable. Kind of at a loss as to what to try next really.
