Port manipulation PINx commands with Arduino Due ?
Hello!
are the port manipulation commands supported in Due ? I have used PINx commands with Arduino Mega to read and write bytes instead of digitalRead() and -Write() , and would like to do the same with Due , and if byte (or word size 16 bits) simultaneous reading and writing is possible , how should the PIN command syntax be ?
BR,
Seppo
I'm trying to work this out as well, at the moment I'm looking in arduino-1.5/hardware/arduino/sam/variants/arduino_due_x/variants.cpp and variants.h, but I haven't figured it out yet.
Read here there some more info (all the way to the end): http://arduino.cc/forum/index.php/topic,129407.0.html
I'm also trying to do port manipulation.
It looks like you might be able to do:
REG_PIOx_ODSR = data_to_set;
to set output data, and:
input_data = REG_PIOx_PDSR;
to get input data, where x is A,B,C or D. The acronyms are “output data status register” and “pin data status register”. You may first need to enable output by writing ones to PIOx_OWER (output write enable register). If you’ve already used standard arduino calls to set the pin in question to be an output, I think that’s all you’ll need to do. See page 646 of the datasheet for more info:
http://www.atmel.com/Images/doc11057.pdf
The registers all follow the same naming convention, it’s always REG_PIOx_, so it’s easy to translate register names in the datasheet to variable names in your sketch.
I can’t test as I don’t have a Due yet, I’d love to know if this works though.
Hi.
Like Baltasar, I'm struggling with this issue also.
The compiler likes that method to deal with ports, but now I'm stuck after. It has something to do with pins_arduino.h.
When compiler gets this lines:
P_RS = portOutputRegister(digitalPinToPort(RS)); B_RS = digitalPinToBitMask(RS); P_WR = portOutputRegister(digitalPinToPort(WR)); B_WR = digitalPinToBitMask(WR); P_CS = portOutputRegister(digitalPinToPort(CS)); B_CS = digitalPinToBitMask(CS); P_RST = portOutputRegister(digitalPinToPort(RST)); B_RST = digitalPinToBitMask(RST);
It says:
D:\Docs\Arduino\arduino-1.5\libraries\UTFT\UTFT.cpp: In constructor 'UTFT::UTFT(byte, int, int, int, int, int)': D:\Docs\Arduino\arduino-1.5\libraries\UTFT\UTFT.cpp:158: error: base operand of '->' has non-pointer type 'const PinDescription' D:\Docs\Arduino\arduino-1.5\libraries\UTFT\UTFT.cpp:159: error: base operand of '->' has non-pointer type 'const PinDescription' D:\Docs\Arduino\arduino-1.5\libraries\UTFT\UTFT.cpp:160: error: base operand of '->' has non-pointer type 'const PinDescription' D:\Docs\Arduino\arduino-1.5\libraries\UTFT\UTFT.cpp:161: error: base operand of '->' has non-pointer type 'const PinDescription' D:\Docs\Arduino\arduino-1.5\libraries\UTFT\UTFT.cpp:162: error: base operand of '->' has non-pointer type 'const PinDescription' D:\Docs\Arduino\arduino-1.5\libraries\UTFT\UTFT.cpp:163: error: base operand of '->' has non-pointer type 'const PinDescription' D:\Docs\Arduino\arduino-1.5\libraries\UTFT\UTFT.cpp:164: error: base operand of '->' has non-pointer type 'const PinDescription' D:\Docs\Arduino\arduino-1.5\libraries\UTFT\UTFT.cpp:165: error: base operand of '->' has non-pointer type 'const PinDescription'
This is pointing to file variant.cpp, to this function:
/* * Pins descriptions */ extern const PinDescription g_APinDescription[]= { // 0 .. 53 - Digital pins // ---------------------- (...)
The operand '->' is not seen inside the function, I don't understand what the compiler want.
Can someone help?
alvesjc,
I'm not sure what you're doing, but it looks like the functions you're calling expect pointers to PinDescriptions objects, and that you're giving them actual PinDescription objects rather than pointers. So the -> operator (which may be implicit in that function even though you can't see it) fails. See here for an explanation:
http://stackoverflow.com/questions/1238613/what-is-the-difference-between-the-dot-operator-and-in-c
So I can't tell from your code which variables are PinDescriptions, but if you put an ampersand in front of them, you'll be converting them to pointers and then the -> operator will work.
So if RS is a PinDescription, try digitalPinToPort(&RS).
Hi.
RS is a variable, basically, the pin corresponding to RS signal to TFT. RS is for example, PIN39, is passed when the lib is initialized:
" class UTFT { public: UTFT(); UTFT(byte model, int RS, int WR,int CS, int RST, int SER=0); (...) " RS is for exemple, 39.
Hm. I'm not sure what's going on then. If you're just trying to read and write directly from ports, have you tried the method I suggested in reply #3?
While trying your sugestion, the errors are now:
D:\Docs\Arduino\arduino-1.5\libraries\UTFT\UTFT.cpp: In constructor 'UTFT::UTFT(byte, int, int, int, int, int)': D:\Docs\Arduino\arduino-1.5\libraries\UTFT\UTFT.cpp:158: error: invalid types 'const PinDescription [][int*]' for array subscript D:\Docs\Arduino\arduino-1.5\libraries\UTFT\UTFT.cpp:159: error: invalid types 'const PinDescription [][int*]' for array subscript D:\Docs\Arduino\arduino-1.5\libraries\UTFT\UTFT.cpp:160: error: invalid types 'const PinDescription [][int*]' for array subscript D:\Docs\Arduino\arduino-1.5\libraries\UTFT\UTFT.cpp:161: error: invalid types 'const PinDescription [][int*]' for array subscript D:\Docs\Arduino\arduino-1.5\libraries\UTFT\UTFT.cpp:162: error: invalid types 'const PinDescription [][int*]' for array subscript D:\Docs\Arduino\arduino-1.5\libraries\UTFT\UTFT.cpp:163: error: invalid types 'const PinDescription [][int*]' for array subscript D:\Docs\Arduino\arduino-1.5\libraries\UTFT\UTFT.cpp:164: error: invalid types 'const PinDescription [][int*]' for array subscript D:\Docs\Arduino\arduino-1.5\libraries\UTFT\UTFT.cpp:165: error: invalid types 'const PinDescription [][int*]' for array subscript
chrisbillington:
Hm. I’m not sure what’s going on then. If you’re just trying to read and write directly from ports, have you tried the method I suggested in reply #3?
Yes, that method solved the compilation problem at least. I can’t test it yet because the other errors.
But the port handling is now this:
void UTFT::LCD_Writ_Bus(char VH,char VL, byte mode)
	switch (mode)
	case 16:
#if defined(__SAM3X8E__)
		//DB00 on PIN37 -> PIO_PC5
		REG_PIOC_ODSR=(VL<<5) & 0x20;
		//DB01 on PIN36 -> PIO_PC4
		REG_PIOC_ODSR=(VL<<3) & 0x10;
		//DB02 on PIN35 -> PIO_PC3
		REG_PIOC_ODSR=(VL<<1) & 0x08;
		//DB03 on PIN34 -> PIO_PC2
		REG_PIOC_ODSR=(VL>>1) & 0x04;
		//DB04 on PIN33 -> PIO_PC1
		REG_PIOC_ODSR=(VL>>3) & 0x02;
		//DB05 on PIN32 -> PIO_PD10
		REG_PIOD_ODSR=(VL<<5) & 0x400;
		//DB06 on PIN31 -> PIO_PA7
		REG_PIOA_ODSR=(VL<<1) & 0x80;
		//DB07 on PIN30 -> PIO_PD9
		REG_PIOD_ODSR=(VL<<2) & 0x200;
		//DB08 on PIN22 -> PIO_PB26
		REG_PIOB_ODSR=(VH<<26) & 0x4000000;
		//DB09 on PIN23 -> PIO_PA14
		REG_PIOA_ODSR=(VH<<13) & 0x4000;
		//DB10 on PIN24 -> PIO_PA15
		REG_PIOA_ODSR=(VH<<13) & 0x8000;
		//DB11 on PIN25 -> PIO_PD0
		REG_PIOD_ODSR=(VH>>3) & 0x01;
		//DB12 on PIN26 -> PIO_PD1
		REG_PIOD_ODSR=(VH>>3) & 0x02;
		//DB13 on PIN27 -> PIO_PD2
		REG_PIOD_ODSR=(VH>>3) & 0x04;
		//DB14 on PIN28 -> PIO_PD3
		REG_PIOD_ODSR=(VH>>3) & 0x08;
		//DB15 on PIN29 -> PIO_PD6
		REG_PIOD_ODSR=(VH>>1) & 0x40;
#endif
		pulse_low(P_WR, B_WR);
void UTFT::_set_direction_registers(byte mode)
	if (mode==16)
		REG_PIOA_OWER=0xc080; //PA7,PA14,PA15 enable
		REG_PIOB_OWER=0x4000000; //PB26 enable
		REG_PIOC_OWER=0x3e; //PC1 - PC5 enable
		REG_PIOD_OWER=0x64f; //PD0-3,PD6,PD9-10 enable
#endif
After this, it stoped complaining about the PORT defenitions, so I guess you’r right! :wink:
Hi!
tested the syntax :
int input_data = REG_PIOD_PDSR;
and works ok and the command reads the D port ok with this one command, tested by changing all the input states,
will be testing the A,B and C ports and outputs tomorrow , will report more then,
Chris , thanks for info !
BR, Seppo
Hi.
Ok, I've figured out what is wrong.
Looking to arduino mega pins_arduino.h we find this:
const uint8_t PROGMEM digital_pin_to_port_PGM[] = {
    // PORTLIST
    PE  , // PE 0 ** 0 ** USART0_RX
    PE  , // PE 1 ** 1 ** USART0_TX
    PE  , // PE 4 ** 2 ** PWM2
    PE  , // PE 5 ** 3 ** PWM3
    PG  , // PG 5 ** 4 ** PWM4
    PE  , // PE 3 ** 5 ** PWM5
    PH  , // PH 3 ** 6 ** PWM6
    PH  , // PH 4 ** 7 ** PWM7
    PH  , // PH 5 ** 8 ** PWM8
    PH  , // PH 6 ** 9 ** PWM9
    PB  , // PB 4 ** 10 ** PWM10
    PB  , // PB 5 ** 11 ** PWM11
    PB  , // PB 6 ** 12 ** PWM12
    PB  , // PB 7 ** 13 ** PWM13
    PJ  , // PJ 1 ** 14 ** USART3_TX
    PJ  , // PJ 0 ** 15 ** USART3_RX
    PH  , // PH 1 ** 16 ** USART2_TX
    PH  , // PH 0 ** 17 ** USART2_RX
    PD  , // PD 3 ** 18 ** USART1_TX
    PD  , // PD 2 ** 19 ** USART1_RX
    PD  , // PD 1 ** 20 ** I2C_SDA
    PD  , // PD 0 ** 21 ** I2C_SCL
    PA  , // PA 0 ** 22 ** D22
    PA  , // PA 1 ** 23 ** D23
    PA  , // PA 2 ** 24 ** D24
    PA  , // PA 3 ** 25 ** D25
    PA  , // PA 4 ** 26 ** D26
    PA  , // PA 5 ** 27 ** D27
    PA  , // PA 6 ** 28 ** D28
    PA  , // PA 7 ** 29 ** D29
    PC  , // PC 7 ** 30 ** D30
    PC  , // PC 6 ** 31 ** D31
    PC  , // PC 5 ** 32 ** D32
    PC  , // PC 4 ** 33 ** D33
    PC  , // PC 3 ** 34 ** D34
    PC  , // PC 2 ** 35 ** D35
    PC  , // PC 1 ** 36 ** D36
    PC  , // PC 0 ** 37 ** D37
    PD  , // PD 7 ** 38 ** D38
    PG  , // PG 2 ** 39 ** D39
    PG  , // PG 1 ** 40 ** D40
    PG  , // PG 0 ** 41 ** D41
    PL  , // PL 7 ** 42 ** D42
    PL  , // PL 6 ** 43 ** D43
    PL  , // PL 5 ** 44 ** D44
    PL  , // PL 4 ** 45 ** D45
    PL  , // PL 3 ** 46 ** D46
    PL  , // PL 2 ** 47 ** D47
    PL  , // PL 1 ** 48 ** D48
    PL  , // PL 0 ** 49 ** D49
    PB  , // PB 3 ** 50 ** SPI_MISO
    PB  , // PB 2 ** 51 ** SPI_MOSI
    PB  , // PB 1 ** 52 ** SPI_SCK
    PB  , // PB 0 ** 53 ** SPI_SS
    PF  , // PF 0 ** 54 ** A0
    PF  , // PF 1 ** 55 ** A1
    PF  , // PF 2 ** 56 ** A2
    PF  , // PF 3 ** 57 ** A3
    PF  , // PF 4 ** 58 ** A4
    PF  , // PF 5 ** 59 ** A5
    PF  , // PF 6 ** 60 ** A6
    PF  , // PF 7 ** 61 ** A7
    PK  , // PK 0 ** 62 ** A8
    PK  , // PK 1 ** 63 ** A9
    PK  , // PK 2 ** 64 ** A10
    PK  , // PK 3 ** 65 ** A11
    PK  , // PK 4 ** 66 ** A12
    PK  , // PK 5 ** 67 ** A13
    PK  , // PK 6 ** 68 ** A14
    PK  , // PK 7 ** 69 ** A15
const uint8_t PROGMEM digital_pin_to_bit_mask_PGM[] = {
    // PIN IN PORT
    _BV( 0 )    , // PE 0 ** 0 ** USART0_RX
    _BV( 1 )    , // PE 1 ** 1 ** USART0_TX
    _BV( 4 )    , // PE 4 ** 2 ** PWM2
    _BV( 5 )    , // PE 5 ** 3 ** PWM3
    _BV( 5 )    , // PG 5 ** 4 ** PWM4
    _BV( 3 )    , // PE 3 ** 5 ** PWM5
    _BV( 3 )    , // PH 3 ** 6 ** PWM6
    _BV( 4 )    , // PH 4 ** 7 ** PWM7
    _BV( 5 )    , // PH 5 ** 8 ** PWM8
    _BV( 6 )    , // PH 6 ** 9 ** PWM9
    _BV( 4 )    , // PB 4 ** 10 ** PWM10
    _BV( 5 )    , // PB 5 ** 11 ** PWM11
    _BV( 6 )    , // PB 6 ** 12 ** PWM12
    _BV( 7 )    , // PB 7 ** 13 ** PWM13
    _BV( 1 )    , // PJ 1 ** 14 ** USART3_TX
    _BV( 0 )    , // PJ 0 ** 15 ** USART3_RX
    _BV( 1 )    , // PH 1 ** 16 ** USART2_TX
    _BV( 0 )    , // PH 0 ** 17 ** USART2_RX
    _BV( 3 )    , // PD 3 ** 18 ** USART1_TX
    _BV( 2 )    , // PD 2 ** 19 ** USART1_RX
    _BV( 1 )    , // PD 1 ** 20 ** I2C_SDA
    _BV( 0 )    , // PD 0 ** 21 ** I2C_SCL
    _BV( 0 )    , // PA 0 ** 22 ** D22
    _BV( 1 )    , // PA 1 ** 23 ** D23
    _BV( 2 )    , // PA 2 ** 24 ** D24
    _BV( 3 )    , // PA 3 ** 25 ** D25
    _BV( 4 )    , // PA 4 ** 26 ** D26
    _BV( 5 )    , // PA 5 ** 27 ** D27
    _BV( 6 )    , // PA 6 ** 28 ** D28
    _BV( 7 )    , // PA 7 ** 29 ** D29
    _BV( 7 )    , // PC 7 ** 30 ** D30
    _BV( 6 )    , // PC 6 ** 31 ** D31
    _BV( 5 )    , // PC 5 ** 32 ** D32
    _BV( 4 )    , // PC 4 ** 33 ** D33
    _BV( 3 )    , // PC 3 ** 34 ** D34
    _BV( 2 )    , // PC 2 ** 35 ** D35
    _BV( 1 )    , // PC 1 ** 36 ** D36
    _BV( 0 )    , // PC 0 ** 37 ** D37
    _BV( 7 )    , // PD 7 ** 38 ** D38
    _BV( 2 )    , // PG 2 ** 39 ** D39
    _BV( 1 )    , // PG 1 ** 40 ** D40
    _BV( 0 )    , // PG 0 ** 41 ** D41
    _BV( 7 )    , // PL 7 ** 42 ** D42
    _BV( 6 )    , // PL 6 ** 43 ** D43
    _BV( 5 )    , // PL 5 ** 44 ** D44
    _BV( 4 )    , // PL 4 ** 45 ** D45
    _BV( 3 )    , // PL 3 ** 46 ** D46
    _BV( 2 )    , // PL 2 ** 47 ** D47
    _BV( 1 )    , // PL 1 ** 48 ** D48
    _BV( 0 )    , // PL 0 ** 49 ** D49
    _BV( 3 )    , // PB 3 ** 50 ** SPI_MISO
    _BV( 2 )    , // PB 2 ** 51 ** SPI_MOSI
    _BV( 1 )    , // PB 1 ** 52 ** SPI_SCK
    _BV( 0 )    , // PB 0 ** 53 ** SPI_SS
    _BV( 0 )    , // PF 0 ** 54 ** A0
    _BV( 1 )    , // PF 1 ** 55 ** A1
    _BV( 2 )    , // PF 2 ** 56 ** A2
    _BV( 3 )    , // PF 3 ** 57 ** A3
    _BV( 4 )    , // PF 4 ** 58 ** A4
    _BV( 5 )    , // PF 5 ** 59 ** A5
    _BV( 6 )    , // PF 6 ** 60 ** A6
    _BV( 7 )    , // PF 7 ** 61 ** A7
    _BV( 0 )    , // PK 0 ** 62 ** A8
    _BV( 1 )    , // PK 1 ** 63 ** A9
    _BV( 2 )    , // PK 2 ** 64 ** A10
    _BV( 3 )    , // PK 3 ** 65 ** A11
    _BV( 4 )    , // PK 4 ** 66 ** A12
    _BV( 5 )    , // PK 5 ** 67 ** A13
    _BV( 6 )    , // PK 6 ** 68 ** A14
    _BV( 7 )    , // PK 7 ** 69 ** A15
These two arrays are the key to allow to easily choose any pin and immediately know is port and bit number to build a mask.
These arrays are note present in Due pins_arduino.h (that links to variant.cpp).
If I force the pins and get their port and bit, this lib will certainly work, but at the cost of loosing flexibility.
Is there any problem about including this arrays with due pin tables to pins_arduino.h?
I think i've got a little more of this picture.
The compiler complains that: " D:\Docs\Arduino\arduino-1.5\libraries\UTFT\UTFT.cpp: In constructor 'UTFT::UTFT(byte, int, int, int, int, int)': D:\Docs\Arduino\arduino-1.5\libraries\UTFT\UTFT.cpp:158: error: base operand of '->' has non-pointer type 'const PinDescription' " When in the UTFT lib the compiler reaches the line 158:
Well, this calls from arduino.h the following:
define digitalPinToPort(P) ( g_APinDescription[P]->pPort )
g_APinDescription[] is one array of type "PinDescription" that is this struct in arduino.h:
/* Types used for the tables below */
typedef struct _PinDescription
  Pio* pPort ;
  uint32_t ulPin ;
  uint32_t ulPeripheralId ;
  EPioType ulPinType ;
  uint32_t ulPinConfiguration ;
  uint32_t ulPinAttribute ;
  EAnalogChannel ulAnalogChannel ; /* Analog pin in the Arduino context (label on the board) */
  EAnalogChannel ulADCChannelNumber ; /* ADC Channel number in the SAM device */
  EPWMChannel ulPWMChannel ;
  ETCChannel ulTCChannel ;
} PinDescription ;
This struct is instantiated then with:
/* Pins table to be instanciated into variant.cpp */ extern const PinDescription g_APinDescription[] ;
All this seems logical but it doesn't work.
Based on the info in this link: http://cplusplus.syntaxerrors.info/index.php?title=Base_operand_of_arrow_has_non-pointer_type_%E2%80%98Foo%E2%80%99
I've tried to replace this:
with this:
define digitalPinToPort(P) ( g_APinDescription[P].pPort )
But then I have the following error:
D:\Docs\Arduino\arduino-1.5\libraries\UTFT\UTFT.cpp: In constructor 'UTFT::UTFT(byte, int, int, int, int, int)': D:\Docs\Arduino\arduino-1.5\libraries\UTFT\UTFT.cpp:158: error: invalid conversion from 'volatile RwReg' to 'volatile uint8_t*'
RS is pin 38, and that is what is passed to the define.
Can someone help with this? I'm clueless....
I can't figure out what you are trying to do, or what you've done. You keep posting segments of pins_arduino.h and variant.cpp, and never the code that you've actually written...
pins_arduino.h and variant.cpp are the modules that translate from the names that the Arduino environment uses (1, 2, 3, PIN_LED_13) to the addresses used by the CPU internally. They have nothing to do with "direct port manipulation" except as way to identify which Arduino pins match up with which ports and bits.
The Arduino pin numbers are small and consecutive integers, while the ports are large 32bit addresses, and the bits are bit numbers. In the Due implementation, the Arduino pin number is used as an index into an array of structures with various information about the pin/port/bit/function. In the MEGA implementation, the pin number is used as an index into various parallel simple arrays that each convey part the same set of information. It's part of the power of the "variant" code setup that two different boards can have substantially different implementations.
And yes, to do direct port manipulation, you give up a LOT of the flexibility that you'd get from using the Arduino pin names.
Hi Westfw.
What I’m trying to do, is to port UTFT library from MEGA to work with DUE. This library is from Henning Karlsen, but since e doesn’t have a DUE at the moment, he can’t work on the lib now.
The original library is here:
http://www.henningkarlsen.com/electronics/library.php?id=51
What is needed to port is all the low level functions that deal with ports. Part of that is done following reply #3, that is, the TFT data bus. Now I’m stuck in the control pins of the TFT.
You can find attached the library with the changes I’ve made so far.
My last post shows the point were I’m bumping now.
The code that is failing is in the file “utft.cpp” in the lines mentioned in last post.
Can you or someone else help me out with this?
Thank you.
BR,
Joao
UTFT.zip (706 KB)
The other way of doing direct port manipulation looks like this:
PIOx->register=value;
long r = PIOx->register;
where x is A,B,C or D and register is as in the data sheet
For example:
PIOB->PIO_SODR=1<<27; //lights the LED
PIOB->PIO_CODR=1<<27; //clears it
boolean p12=!!(PIOD->PIO_PDSR & (1<<8)); //read pin 12
I had a go at writing some digitalReadDirect/digitalWriteDirect functions but you might want to give them some more thorough testing as I only checked if it worked with the LED :slight_smile:
inline void digitalWriteDirect(int pin, boolean val){
  if(val) g_APinDescription[pin].pPort -> PIO_SODR = g_APinDescription[pin].ulPin;
  else    g_APinDescription[pin].pPort -> PIO_CODR = g_APinDescription[pin].ulPin;
inline int digitalReadDirect(int pin){
  return !!(g_APinDescription[pin].pPort -> PIO_PDSR & g_APinDescription[pin].ulPin);
  pinMode(13, OUTPUT);
  pinMode(12, INPUT);
  digitalWriteDirect(13, HIGH);
  digitalWriteDirect(13, LOW);
  Serial.println(digitalReadDirect(12));
Hummm, you're using the"."!
but it doesn't work if I put the dot in this line anyway:
I'll test your code later, maybe I can implement it directly in lib.
Thank you
Can’t you just use digitalWrite() for the control pins, as a first effort?
stimmer:
For example:
I had a go at writing some digitalReadDirect/digitalWriteDirect functions but you might want to give them some more thorough testing as I only checked if it worked with the LED :)
  if(val) g_APinDescription[pin].pPort → PIO_SODR = g_APinDescription[pin].ulPin;
  else    g_APinDescription[pin].pPort → PIO_CODR = g_APinDescription[pin].ulPin;
  return !!(g_APinDescription[pin].pPort → PIO_PDSR & g_APinDescription[pin].ulPin);
  pinMode(12, INPUT);
your code is working pretty well man, thank you a lot… i gained about almost 40% speed in my parallel flash memory writer :wink:
westfw:
Now I'm stuck in the control pins of the TFT.
Can't you just use digitalWrite() for the control pins, as a first effort?
Yes, I'll try that also.
Regards,
Joao
